Like Tree780Likes
MTC3
Old 12-09-2024 | 07:55 AM
  #76
busman's Avatar
Originally Posted by Bar
Orlowski's chassis got bent at the worlds. The only decent one I have seen looks to be the AMX one. The AMX chassis is a very different shape due to not using a conventional shock absorber though. I heard that some of the steel chassis that used were only 1mm thick
So, Apparently you haven’t read the whole thread!?
busman is offline
Old 12-09-2024 | 01:25 PM
  #77
bmwjoon's Avatar
Not to beat a dead horse but the other day as I was working I saw a screw fall out of my laptop. It is a flathead screw but it isn't tapered. The thickness of the head is somewhere around 1/2mm. You would have to use locating pins but it might work alright. Still doesn't address the manufacturing and cost of it like we discussed. Still a cool concept even if we never actually see it.
bmwjoon is offline
Old 12-09-2024 | 03:17 PM
  #78
gigaplex's Avatar
It was probably also an M2 thread and didn't have much load on it.
gigaplex is online now
Old 12-09-2024 | 04:14 PM
  #79
bmwjoon's Avatar
Yup, they are dinky for sure. Wouldn't survive my love of boards.
MTC2 chassis had a lot of nice machining. If they went to a steel chassis with some holes to get the right flex and weight it could be doable. I guess we'll see in like a year or so, LOL!
bmwjoon is offline
Old 12-25-2024 | 02:47 AM
  #80
Any news about the car ? Release date ? Anything ??
Sarop is offline
Old 12-25-2024 | 07:28 AM
  #81
dawgmeat's Avatar
late spring early summer
dawgmeat is offline
Old 01-08-2025 | 08:00 PM
  #82
Nuno Gancho's Avatar
Will there be a new FF? Thanks
busman likes this.
Nuno Gancho is offline
Old 01-11-2025 | 10:01 PM
  #83
Typeone's Avatar
This car looks great. Seen it first hand at worlds. Think it would be a great car to wait on of looking for a new tc car.
tbrymer likes this.
Typeone is offline
Old 01-17-2025 | 11:50 PM
  #84
ozzyNEOdriver's Avatar
you can easily run a 1mm chassis. you simply design the bulkhead to have a tapered initial entry hole for the screw that matches the screw head angle. the screw head acts as a self centring screw similar to those used on the awesomatix bulkheads and shocks. the screw sits partially inside the bulkhead, meaning the screw head can sit flush on a 1mm chassis. being high tensile carbon steel the risk of the screw ripping through is highly unlikely.
this may be also why awx have not released their steel chassis yet. if awx is running 1mm steel chassis's, it may require different bulkheads, considering steel chassis are expensive this means a retail cost for the steel chassis with bulkheads is not cheap, maybe half the price of a kit! (steel chassis alone in low numbers costs like $300aussie to make, about 200usd)
ozzyNEOdriver is offline
Old 01-18-2025 | 12:50 AM
  #85
gigaplex's Avatar
It's easy to do but it leaves very little material engaging on the countersunk head. Screws could pull through in a crash.
Old 01-18-2025 | 06:59 AM
  #86
dawgmeat's Avatar
The future of TC
Robbob and blwaz23 like this.
dawgmeat is offline
Old 01-18-2025 | 07:57 AM
  #87
blwaz23's Avatar
Originally Posted by dawgmeat
The future of TC
Whats the advantage? Or the screws are small enough to use with a thinner chassis?
blwaz23 is offline
Old 01-18-2025 | 08:06 AM
  #88
Its being developed but yes ... thinner chassis with out the worry of material to capture the screw heads.
Robbob is offline
Old 01-18-2025 | 08:10 AM
  #89
Marcos.J's Avatar
Super Moderator
well good news with the new balsa wood chassis is that you can just use Elmer’s glue to glue the bulkheads once the pros use it everyone will follow like lol
Marcos.J is offline
Old 01-18-2025 | 08:19 AM
  #90
Gorilla glue .... Elmers isnt water board proof
Marcos.J likes this.
Robbob is offline
