eXcelerate RC Prodigy Formula 1 >
Like Tree1136Likes
Old 05-07-2026 | 10:32 PM
  #1081
Lot's of new parts on the web site - especially a Team Kit for the F1 - that's a good price for the upgrades.
HD-F1 likes this.
belewis01 is offline
Old 05-08-2026 | 06:45 AM
  #1082
MiamizFinest's Avatar
How long of a sensor wire do I need for this car?
MC Hamilton likes this.
MiamizFinest is offline
Old 05-08-2026 | 07:21 AM
  #1083
HD-F1's Avatar
From: In the car taking my kid to another race track.
That F1 Team kit is really close to what a lot of the guys are running.
HD-F1 is offline
Old 05-08-2026 | 09:32 AM
  #1084
Raced the car last weekend. It was very fast, I'm quite happy with the handling. Unfortunately, had some durability issues during the mains that probably costed me the victory. Learned a few things though! Rear droop is critical! too much and you will definitely have the rear dampers come out with just being too agressive on the kerbs. I ended up using button head screws with shims to set it up. Beware that you need very thin shims to adjust because the lever is very short and a tiny change makes a big impact on the final droop. Basically, a 0.25 mm shim changes the droop by 1.5-2.0 mm. Using some 0.05 and 0.10 shims, I was able to set it to my liking. Other thing I found out is you need threadlock on those droop screws and the purple one won't be enough. You need blue otherwise the screws will back out and cause all sorts of issues. Ask me how I know! Played a bit with the pivot heights. I could definitely feel the difference for the roll, not so much for the up and down.
The Excelerate tires were great. Brand new, they needed about 2 practice runs to be perfect and they stayed consistent all weekend long after that. I don't know if they changed the front rims, but with this new set, the bearings fit much tighter than on the first set I had.
Martin Paradis
HD-F1 and MC Hamilton like this.
rhodopsine is offline
Old 05-08-2026 | 12:04 PM
  #1085
Originally Posted by TimPotter
too wide
Too wide by only 1.96mm or less on the diff side with excelerate rims, by my calculations with my good eye(..lol..)... It might be good with other offset rims...This issue is better solved with better offset rims(if available) or run two millimeters shorter on the left side(ouch): associated F1 ball diff kits might be very hard to get...Best to change the Roar Rules to 196mm or 200mm F1 width just like the 1S/13.5t rule....lol....None of the tracks tech F1 rear width anyway...
bertrandsv87 is offline
Old 05-11-2026 | 07:01 AM
  #1086
MC Hamilton's Avatar
Many of you saw the F1 team kits hit the site last week. These have all the go fast parts that people like Brayden Mahar have been using to stack up podium finishes this season. Ken confirmed that all newly boxed kits will have all upgrade parts included. I love that Ken and Josh do these rolling changes.
Some other parts now available. F1 electronics tray, F1 car stand, thicker V2 damper rod forks to eliminate bending, and new metal pivot sockets (which work best with the new F1 roll plates that have screws to lock in the pivots).
HD-F1 likes this.
MC Hamilton is offline
Old 06-01-2026 | 03:38 PM
  #1087
How are you guys keeping the front wing from dragging in the corners? Front ride height is 4.2mm, but the corners of the wing only sit about 2-3mm off the ground and they are black and sticky after every run.
kn7671 is offline
Old 06-01-2026 | 03:54 PM
  #1088
Teflon tape on the bottom and let it drag!
kn7671 likes this.
PROMODVETTE is offline
Old 06-01-2026 | 04:42 PM
  #1089
Of course, doh! The simple solutions are sometimes the best solutions.
kn7671 is offline
  #1090
Either too much chassis rake and the nose is pointed down.
Or your wing has been abused and is bent down.
The wing edges should sit 2mm above the chassis to begin with so the corners should naturally be 6.2mm by your ride height.
How much droop? Could be dropping the nose to hard on entry.
What spring? Maybe some more preload or find one slightly heavier to help stop the nose from dropping so fast.
Heat the wing and curve the ends up slightly.
Raise ride height some ... 4.5/4.8
At 4.5 ride height I was just touching the outer front corners.
I reduced droop to less then 1mm and stepped my front springs up slightly to another brand while tuning the car.
After those two changes I hardly touch the corners unless i slammed the car in on a 180
Team Wenz and MC Hamilton like this.
Robbob is online now
Old 06-02-2026 | 08:25 AM
  #1091
robk's Avatar
Mini torch, you can heat it up and put a little bend in there to keep it off the track.
robk is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
