Charging Help! New to Lipo.
Charging help!
long story, i bought a spektrum s1100 charger because i have an Aarma 1/8 onroad basher to goof off with. With that basher I bought 2 5000mah Spektrum 2s Batteries. Those charge just fine no problems.
Here comes the problem, i decided to get 2 Protech Lihv 2s 6400mah batteries for my TLR 22 5.0. The Spektrum charger is supposed to charge Lihv batteries. I bought the connector that I assumed would work. 5mm barrels +2mm bullet for ballance to the ic3 connector. When I plug the battery into the s1100 charger I get a battery symbol with a question mark. They will not charge.
Thinking there was a compatibility issue, I ordered a different charger, a Protek prodigy 610ez charger and a protec adapter to connect the batteries to the charger, I get the following error "cell connect err"
Last week I was on a tech chat with Amainhobbies.com their tech support sent me out a different brand battery a Tekin 2s 6300mah battery, I get the same error.
I've gone in and set the 610ez to Lihv 2s 6300mah at 6.3A, when I hit start that's when the error occurs, yes I plugged in the balance lead straight into the charger and the balance board that comes with that charger. No luck.
Please help, either I have really bad luck with 3 bad batteries or I've done something wrong, or bought the wrong adapter cables.
Pics of what you have plugged into the charger will help us understand the problem better.
I believe Spektrum has proprietary plugs forcing you to buy their batteries to use their charger without a balance harness... if you buy a non Spektrum battery then you need to purchase a balance harness separately.
