Kyosho MP10 Thread
#1036
I verified all of these, and it's none of the above. You can see in the pic I posted that when the upper link isn't attached to the upright (viewer's right) the down-travel is normal. You can see that the upper link cannot even reach the upright at full droop, but if I lengthen it, the result will be severely positive camber at normal ride height.
#1037
Stock setup has the links on the outside holes of the shock tower. Is this a custom setup?
#1038
#1040
It seems that the shaft is locked up in the outdrive.
#1043
We use the driveshafts, outdrives & rear hubs.
cannot fault them one bit.
#1044
I purchased a few, everything OK, except on two driveshafts for which the pin diameter was 3mm instead of 2.9mm.
So unable to install it.
Generally speaking these parts really look like "official ones".
I am very surprised that the chinese are able to copy with such efficiency.
On the other hand, not such a good buisiness for Kyosho, as the proposed prices are so low... compared to shop prices (from france)
