Kyosho MP10 Thread >
Kyosho MP10 Thread
Like Tree306Likes
Kyosho MP10 Thread
Old 12-28-2023, 06:36 AM
  #1036
captain america's Avatar
Originally Posted by petersen114
Is the C-Hub touching the arm or maybe the sway bar grub screw is causing the issue by being a bit too tight on that side?
I verified all of these, and it's none of the above. You can see in the pic I posted that when the upper link isn't attached to the upright (viewer's right) the down-travel is normal. You can see that the upper link cannot even reach the upright at full droop, but if I lengthen it, the result will be severely positive camber at normal ride height.
wely324 likes this.
captain america is offline
Old 12-28-2023, 08:08 AM
  #1037
Stock setup has the links on the outside holes of the shock tower. Is this a custom setup?
wely324 is offline
Old 12-28-2023, 08:43 AM
  #1038
https://rsrc.biz/en/blog/kyosho-infe...no-savoya-n127
Old 12-28-2023, 08:51 AM
  #1039
Trader Rating: 40 (100%+)
Originally Posted by captain america
Not sure how much of a difference it’ll make, but it appears you have it in the upper inner hole. The setup sheet has it in the middle inner hole.
xenon55 is offline
Old 12-28-2023, 11:11 AM
  #1040
dtr
dtr's Avatar
It seems that the shaft is locked up in the outdrive.
dtr is offline
Old 12-28-2023, 01:23 PM
  #1041
Mickey_B's Avatar
Trader Rating: 7 (89%+)
def not right, I’d double check to make sure those are the correct mounting holes if the tie rod is correct length.
You don’t have mounted to the chassis from what I see in the pics. So droop is going to be off until you mount. Once you mount your not gonna get that much droop because of the droop screws.
Mickey_B is offline
Old 01-15-2024, 12:50 PM
  #1042
Mickey_B's Avatar
Ordered a bunch of mp10 parts along with a chassis from Aliexpress.com. Will post how they compare to the ones from Japan.
l
Mickey_B is offline
Old 01-15-2024, 06:55 PM
  #1043
We use the driveshafts, outdrives & rear hubs.
cannot fault them one bit.
MonsterJuice is offline
Old 01-18-2024, 11:16 PM
  #1044
I purchased a few, everything OK, except on two driveshafts for which the pin diameter was 3mm instead of 2.9mm.
So unable to install it.
Generally speaking these parts really look like "official ones".
I am very surprised that the chinese are able to copy with such efficiency.
On the other hand, not such a good buisiness for Kyosho, as the proposed prices are so low... compared to shop prices (from france)
Rati is offline
