Like Tree11Likes
HB E8 World Spec
Old 06-14-2024 | 12:44 PM
  #31
Originally Posted by pink_sleeve
Are you running 3S in both?
Haven't tested any 3S setups yet, need to get 32P gears for that I believe.
billdelong is offline
Old 06-14-2024 | 07:27 PM
  #32
pink_sleeve's Avatar
wow. You run a 2500 kv motor in buggy on 4S
pink_sleeve is offline
Old 06-15-2024 | 07:09 AM
  #33
Thanks for the info Bill, I checked that out on Amazon.
Fastfred1952 is offline
Old 06-15-2024 | 07:37 AM
  #34
I have since switched back to 2400KV from HW, both on 15T pinions, you can run a lower KV but may need to gear up if you want to be competitive, I prefer high KV so the car accelerates slower (less torque with higher KV as the trade off) in the chicanes to get more grip
Old 09-13-2025 | 08:41 AM
  #35
rfleck's Avatar
Default E819rs chassis dremel mod for E8 Worlds
I have a new E819RS chassis and am needing to replace my worn e8 worlds chassis.
I recall others were modifying the front droop tabs of the E819RS to accommodate the E8 worlds front end, but can't find the post. Can anyone provide the instructions? I don't want to remove too much material.
Thanks, Ron
rfleck is offline
Old 09-13-2025 | 09:08 AM
  #36
Thanks, Ron
unfortunately the file was on the website that you could print and tape to your RS chassis, since the website is down the next best thing is take your worn E8 chassis and trace the cut lines onto the RS chassis with a silver sharpie to get the same result.
Old 09-13-2025 | 09:33 AM
  #37
rfleck's Avatar
Thanks Bill!
I lined them up and came t the same conclusion. Cheers buddy!
rfleck is offline
