Like Tree211Likes
Tamiya TRF103
Old 06-09-2022 | 11:24 AM
  #361
Originally Posted by StockRc
Thanks everyone for the set up tips. Great car but we are now allowing non Tamiya cars will shelf the trf103 as worried about parts in the future
Switching to another F1 chassis is fun, but do consider the cost includes getting a new set of parts. Getting a good stock of spare parts for the current RRF103 could be relatively inexpensive as compared to starting up a new car.
A suggestion is when you buy spares for your Tamiya car, store the parts bags carefully. Those parts bags, especially if in pristine condition and unopened, will be of interest to collectors on the auction sites.
F1jet_ is offline
Old 03-22-2023 | 11:07 AM
  #362
J.Gonzalez's Avatar
I am looking for trf 103 roller if anyone is selling.
Pm to discuss.
J.Gonzalez is offline
Old 08-11-2023 | 01:00 PM
  #363
J.Gonzalez's Avatar
Does anyone know if standard f104 front and servo mount will bolt onto the trf103 chassis without modification?
Old 08-18-2023 | 08:33 AM
  #364
Acid_CZ's Avatar
There is high chance it will. Print F104 plate from manual and compare it with TRF103 plate from manual. Window is your friend.
Acid_CZ is offline
Old 08-18-2023 | 05:26 PM
  #365
robk's Avatar
No.
robk is offline
Old 11-06-2023 | 09:56 PM
  #366
asirolli's Avatar
When the TRF104 is coming?
asirolli is offline
Old 11-07-2023 | 12:08 AM
  #367
zuqbu's Avatar
Until Tamiya is rejuvenating their factory racing efforts we‘re lucky if they keep releasing TRF touring cars. Never say never but I would be surprised if there is any other TRF car besides a potential 421 on the horizon.
zuqbu is offline
Old 11-07-2023 | 03:09 AM
  #368
DirkW's Avatar
Also not wanting to jinx it, but unfortunately I think you're right. TRF is sadly almost gone (for now).
DirkW is offline
Old 11-07-2023 | 08:58 AM
  #369
Dan's Avatar
Dan
I stupidly sold my TRF103 a few years ago thinking a TRF104 was just on the horizon.
Dan is offline
Old 01-20-2024 | 05:40 AM
  #370
Default First Post and a Question
Hello all, new here but not super new to RC. Had some way back in the day. Got back in last year with bashers and quickly lost interest. Back to Tamiya and building. M06R, M08R, XV02, XV02RS, TB05R, TA08R and now the TRF103.
This is only my third ball diff build and it doesn’t seem correct. I’ve torn it down and rebuilt it three times now and each time it presented as built correctly and still doesn’t feel correct. It’s set to the manuals setting but it’s notchy but more importantly the spur gear floats which changes the mesh with the spur…is this correct? Thank you in advance.
KingGizzard is online now
Old 01-20-2024 | 10:14 AM
  #371
Acid_CZ's Avatar
Check if all the washers are seated correctly. Floating spur is correct.
Acid_CZ is offline
Old 01-23-2024 | 03:42 PM
  #372
simple's Avatar
The cure for a notchy Tamiya diff is a simple one, and to this day, I don’t understand why Tamiya continued to supply a radial bearing where a thrust bearing should be in their premium F1 kits.
Replace the BD10 bearing with Tamiya part # 53136 one piece thrust bearing. Lube it with black grease, and reinstall with the BD6 spring washers in a “)(“ pattern rather than () as in the instructions.
That will cure the notchiness.
As said above, the float is a good thing, and an indication that the rings are riding only directly on the balls. Not an issue.
robk, photeckk and zuqbu like this.
simple is offline
Old 02-01-2024 | 09:48 AM
  #373
To the admins - why has my last post not been approved?
Old 02-02-2024 | 10:35 AM
  #374
Anyways…
Thank you for the help and the thrust bearing suggestion was perfect. Very smooth now.
Old 04-02-2024 | 06:57 PM
  #375
Anyone have a good starting setup for the TRF103 on high grip asphalt? Also, what are the best F1 rubber tires to use on asphalt?
Apex is offline
