New charger setup
Old 07-08-2023 | 02:16 AM
Default New charger setup
I use:
2s shorties (10th scale) around 5000mah
2s race packs (8th scale) around 8-10000mah
3s soft pack (crawlers) around 50000mah
i have a SkyRC d100v2 and have used it at home on AC and at the track on a leisure battery.
the DC in has failed so looking for something new.
I have noticed a lot of the upmarket chargers are DC only.
I have a spare computer 1300w psu that I can easily take one of the 8pin connectors and slap on a xt90 to (already done that actually)
is there a reason for my use case not to go ahead and get an icharger dx6 and at home charge my batteries using the PSU and at the track continue to use my leisure battery?
I understand that the icharger dx6 has a max input of 65amps, and an 8pin connector is likely to only support 150w which @12v is roughly 12.5amps.
so I guess whilst my psu can output 108amps on the 12v rail. A single cable isn’t going to handle charging multiple batteries at a decent rate and it’ll probably melt the cables from the charger to the psu as the charger pulls the amps to charge the batteries
Skynet5 is offline
Old 07-09-2023 | 08:17 AM
I'm a huge fan of iCharger, some points to consider here:
https://www.rcgroups.com/forums/show...er-is-the-best
billdelong is offline
Old 07-10-2023 | 06:29 PM
disaster999's Avatar
Regional Moderator
Originally Posted by Skynet5
I use:
Why not use the 12V from common rail power instead of relying on the 8pin connector?
disaster999 is offline
Old 07-10-2023 | 06:47 PM
gigaplex's Avatar
If it has an 8 pin connector, it's likely a consumer grade ATX unit without any backplane to solder directly to. So they'll need to use the 8 pin connector or the 24 pin connector. 8 pin sounds easier.
gigaplex is offline
Old 07-12-2023 | 12:12 AM
yeah. That was the plan.
decided to pick up a d300 and Isdt k2 instead. Icharger look good, but for throwing in my bag, sitting out in the sun and getting dirty and the odd bit of rain, figured I’d buy cheaper and buy twice.
Skynet5 is offline
