Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 06-29-2023 | 03:50 PM
  #11701
gigaplex's Avatar
Originally Posted by ohiostatechamp
as long as people sight “in the spirit of control racing” I would argue that bearings should also not be replace as ceramics are not cheap and it requires a special tool to change the bearings correctly. The screws only require tools that most racers already have.
I agree that bearings shouldn't be replaced with ceramics. However that's near impossible to tech. An unenforceable rule is a rule that shouldn't exist. Screws however, they're pretty easy to tech.
Double ceramics are pretty easy to spot though.
Lonestar likes this.
gigaplex is offline
Old 06-29-2023 | 03:58 PM
  #11702
Using Titanium screws was NOT cheating. I read the rules. I spent time sourcing the screws and found a way to improve a motor. I have been race usgt for 4 years and using the screws for almost as long. Only after I posted the results from testing the two different screws was anybody so compelled to change the rules. A knee jurk reaction like NASCAR when motors become too fast after builders find a way. I had 3 motors teched at this years ROAR nationals and NON were flagged for screws. The NEW current rules still fall short. If you think I used titanium because of weight then you missed the point. Weight means nothing when you have to add it to the chassis anyway. Non-Metallic means it must contain metal. Aluminum, Titanium, and stainless steel are Metallic. The question is do I want to spend my time sourcing Metallic materials that are NON MAGNETIC only to be called a cheater again BECAUSE I READ YOUR DAMN RULE BOOK.
jesus christ
bentouttashape is offline
Old 06-29-2023 | 05:11 PM
  #11703
There's a question that doesn't seem to be asked in the place of all the arguing. What measurable advantage does a set of titanium motor screws give? Is it a whole second per lap? Is it a half second per lap? A quarter second? A tenth?
Or is it one of those "because we can and we're the ruling body" rules?
Sabin is offline
Old 06-29-2023 | 05:46 PM
  #11704
hanulec's Avatar
less punch (less magnetic metal in the can), more top end.
hanulec is offline
Old 06-29-2023 | 05:55 PM
  #11705
gwhiz's Avatar
Originally Posted by busman
I’m going to need a new bucket of popcorn! It’s kinda like going to the movies and watching a movie you really don’t like, but can’t get up and leave.
I don't really want to know why you can't get up and leave.
busman, NutDriver and gigaplex like this.
gwhiz is offline
Old 06-29-2023 | 09:32 PM
  #11706
So... negligible difference. Starting to sound like a rule that was made because they can; a solution looking for a problem.
Sabin is offline
Old 06-29-2023 | 09:42 PM
  #11707
gigaplex's Avatar
Maybe negligible at the club day level when there's half a second per lap separating people, but at the top level when there's a tenth separating the top 10 it makes a noticeable difference.
Lonestar, Flipside6900 and chjosi like this.
gigaplex is offline
Old 06-30-2023 | 03:44 AM
  #11708
Time and money 💰 spent for what??? Plastic Bowling Trophies? I would rather run at the back of the pack with the racers who actually FOLLOW the rules package.
Xpress, simple and NutDriver like this.
mooby64 is offline
Old 06-30-2023 | 04:14 AM
  #11709
Lonestar's Avatar
from the above post iirc, about 200rpm...
How much have people paid in the past to get >1% extra rpm... answer is: a lot.
just love it how all these "spec and slow-ish and designed to get more people in the hobby and lower costs" classes all usually self-destruct after a few years due to the usual motor cheat... er, sorry, improvements shenanigans....
Lonestar is offline
Old 06-30-2023 | 04:41 AM
  #11710
ohiostatechamp's Avatar
Originally Posted by robk
This is a motor that is even more tightly regulated than other "spec" motors. A Roar 21.5 motor is a spec motor.
The idea is to buy it and race it. Not to send it to "Stator Stu" to get it tuned up somehow (???), or to change parts for additional money, or whatever other foolishness.
The idea was to take some of the motor madness out of the class, but it seems like it never stops.
like I have said before. Some motors are faster than others right out of the box. It is also a fact that a new motor can be outside the specs making it illegal for racing. Buy and race has never been part of racing. Especially in spec racing where a small advantage is even bigger. By allowing tweaks, but inside a set parameter, actually allows the motors to be more equal. If your intent was to buy and race, then simply change the rule to “no tweaks and OE parts”.Then your intent would be super clear.
Flipside6900 likes this.
ohiostatechamp is offline
Old 06-30-2023 | 04:44 AM
  #11711
bearngs could be made with a colored inner race. Just a simple look would be all that is required.
Old 06-30-2023 | 04:47 AM
  #11712
not entirely true. You get more punch because the magnetic field is not interrupted by the steel screws. And the steel screw is not trying to pull the rotor back to it.
Flipside6900 and gigaplex like this.
Old 06-30-2023 | 05:50 AM
  #11713
simple's Avatar
Some motors are faster than others right out of the box..... By allowing tweaks, but inside a set parameter, actually allows the motors to be more equal.
The only tweaks that anyone ever needs is a couple gear teeth in either direction depending on what is lacking (top or low end).
The incessant desire to alter a spec motor is redundant.
Xpress likes this.
simple is offline
Old 06-30-2023 | 06:08 AM
  #11714
Billy Kelly's Avatar
Tech Prophet
And we are usually all on the same lap
Billy Kelly is offline
Old 06-30-2023 | 07:02 AM
  #11715
gigaplex's Avatar
Pretty trivial for a 3rd party company to just sell ceramic bearings with the same colored inner race.
NutDriver likes this.
gigaplex is offline
