Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 06-28-2023 | 05:18 PM
  #11686
theproffesor's Avatar
Originally Posted by robk
Yeah, no.
The joke wasn’t in reference to the rules, it was to the contrary.
It a stab at all the A-holes that do mental gymnastics to argue what they are doing isn’t breaking a clearly written rule, therefore making you have to define it down to the enth degree.
robk, Rick Vessell, simple and 3 others like this.
theproffesor is offline
Old 06-28-2023 | 05:23 PM
  #11687
"A part is a part. Be it a brake caliper, a rotor, or an upright assembly, and I can swap out any damn thing I want to. We read your damn rule book."
Sabin is offline
Old 06-28-2023 | 08:02 PM
  #11688
I’m glad we don’t use the usgt motor here in Southern California. Kind of nice to go faster than some 17.5 TC cars while using non belted tires. I’m talking about sportsman class btw.
Xrayray is offline
Old 06-29-2023 | 02:55 AM
  #11689
ohiostatechamp's Avatar
Using Titanium screws was NOT cheating. I read the rules. I spent time sourcing the screws and found a way to improve a motor. I have been race usgt for 4 years and using the screws for almost as long. Only after I posted the results from testing the two different screws was anybody so compelled to change the rules. A knee jurk reaction like NASCAR when motors become too fast after builders find a way. I had 3 motors teched at this years ROAR nationals and NON were flagged for screws. The NEW current rules still fall short. If you think I used titanium because of weight then you missed the point. Weight means nothing when you have to add it to the chassis anyway. Non-Metallic means it must contain metal. Aluminum, Titanium, and stainless steel are Metallic. The question is do I want to spend my time sourcing Metallic materials that are NON MAGNETIC only to be called a cheater again BECAUSE I READ YOUR DAMN RULE BOOK.
Flipside6900 likes this.
ohiostatechamp is offline
Old 06-29-2023 | 04:16 AM
  #11690
gigaplex's Avatar
You broke one of the most important rules in the rule book.
MOST IMPORTANTLY: If it's not in the rules, and does not encompass the spirit of fun, controlled racing with realistic looking cars, consider it illegal. This is called the "Spirit of USGT" Rule.
Yes the wording falls short on the screw rule. But it should be pretty f@*king obvious that the intent is you don't change the screws. You're intentionally looking for a loophole. Which is breaking the most important rule.
gigaplex is offline
Old 06-29-2023 | 07:57 AM
  #11691
oldfool's Avatar
Originally Posted by mrreet2001
any bearings are good to go ...
This legal?
MonkeyCmonkeyDo likes this.
oldfool is offline
Old 06-29-2023 | 08:49 AM
  #11692
Oldfool, don’t waist your money. The tolerance of the bearings are bad and allow the rotor to occasionally contact the stator. They require super high maintenance just to keep them free spinning. The only advantage is that they do not interfere with the timing sensor.
Old 06-29-2023 | 08:54 AM
  #11693
as long as people sight “in the spirit of control racing” I would argue that bearings should also not be replace as ceramics are not cheap and it requires a special tool to change the bearings correctly. The screws only require tools that most racers already have.
Old 06-29-2023 | 09:11 AM
  #11694
Bsthetech's Avatar
“If it’s not in the rules it’s illegal”. Following that logic we’d still be racing rocks rolling down a hill.
Bsthetech is offline
Old 06-29-2023 | 12:06 PM
  #11695
Is it considered cheating to use black steel type430 with less ferrous content than the original steel screws ??? Hopefully they won't be teching the ferrous content of the steel screws anytime soon....lol.....
bertrandsv87 is offline
Old 06-29-2023 | 12:10 PM
  #11696
Raman's Avatar
Just use the damn screws that come with the motor.
Raman is offline
Old 06-29-2023 | 01:32 PM
  #11697
robk's Avatar
This is a motor that is even more tightly regulated than other "spec" motors. A Roar 21.5 motor is a spec motor.
The idea is to buy it and race it. Not to send it to "Stator Stu" to get it tuned up somehow (???), or to change parts for additional money, or whatever other foolishness.
The idea was to take some of the motor madness out of the class, but it seems like it never stops.
robk is offline
Old 06-29-2023 | 01:35 PM
  #11698
busman's Avatar
I’m going to need a new bucket of popcorn! It’s kinda like going to the movies and watching a movie you really don’t like, but can’t get up and leave.
busman is offline
Old 06-29-2023 | 02:54 PM
  #11699
Rick Worth's Avatar
I just started running this class a while back and have had the best fun in a long time. I've not even thought about the motor deal and just tried to work on the chassis and my driving and have had decent success. No need for all the bs that is going on.
Rick Vessell and simple like this.
Rick Worth is offline
Old 06-29-2023 | 03:45 PM
  #11700
thirtydaZe's Avatar
And the entire time you're watching, all you can wonder, are these people embarrassed about themselves?
Rick Vessell, busman and simple like this.
thirtydaZe is offline
