Orca oe101 esc without sensor wire? >
Old 03-30-2023 | 04:36 PM
Default Orca oe101 esc without sensor wire?
I recently picked up a used orca esc and it only works when hooked up to a sensored motor with a sensor cable.
It doesn't seem to want to work when I u plug the sensor wire.
Is this normal behavior for this esc?
Thanks all!
amp3d is offline
Old 03-30-2023 | 04:39 PM
gigaplex's Avatar
I'm not sure if that ESC was designed to have a sensorless mode fallback. But sensored ESCs are supposed to be used with a sensor cable at all times.
gigaplex is offline
Old 03-30-2023 | 11:19 PM
Did you read the manual?
As the manual state: Motor Type: Sensored 540 sized brushless motors
Also in the setup options nothing is written about running sensorless.
Roelof is offline
