Like Tree6Likes
Tight piston and sleeve
Old 03-16-2023 | 11:26 AM
  #16
1995 Monster T's Avatar
More oil lube will fix the problem.
1995 Monster T is offline
Old 03-16-2023 | 11:41 AM
  #17
Originally Posted by Bud
It's the easiest thing in the world to figure out if it's bearings or the pinch. Just take the p/s out and turn it over. Is it smooth? p/s back in. Is it sticking now? Now you know. I've had motorcycle pistons get hot and gall up on the cylinder and have kind of the piston tightening effect he's describing but I've never seen it on one of these little motors. I don't know if it would do that or not.
While running a break in, did you ever notice the engine suddenly runs a bit heavy and slowly comes back to normal again? That was such a moment the piston did grow and polished off again. For several years I was involved with an engine development and have broken in many engines and have seen this grow many times. I was told some manufacturers put their pistons or piston material in an oven to give them a 1st heat treatment to lower this effect.
So a grown piston can be fixed with some oil? Oh wow!
Bud and petersen114 like this.
Roelof is offline
Old 03-16-2023 | 05:13 PM
  #18
Bud
Do you have a franchise or stock in an oil co? Would almost seem that way. Contrary to what you might believe, more oil isn't always the answer.
petersen114 likes this.
Bud is offline
