Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 03-03-2023 | 04:47 PM
  #11521
Originally Posted by rcguyfpr
I am about to use up my old usgt tires. Got a set of the new one with 6 stoke wheels. They are hitting my lower arms on my Xray T4. Use spacer or dremel the wheels?
I had the same problem on the rears only. Used .5mm spacers.
Mberthia is offline
Old 03-05-2023 | 12:43 PM
  #11522
jzone's Avatar
Originally Posted by AverageRacer
Anyone try the Divo on indoor carpet (black carpet)? How does it compare to the J1z which seems to be the gold standard at our track?
don't waste your money. I did lol. did not expect it to be so bulky, you have to cut out and add 2 winglets to the roof top. the bugati look is cool but not competitive. super neutral and feels lazy going around the track. I am going back to my Bwoah....
simple and rctuser12349108765 like this.
jzone is offline
Old 03-05-2023 | 01:11 PM
  #11523
jzone's Avatar
can someone direct me to where I can find more information running the Gravity USGT spec motor. looking for gearing help
jzone is offline
Old 03-05-2023 | 06:21 PM
  #11524
MidwestRacer's Avatar
It has been covered, but I will help. I run the motor on a black carpet track 48'x80'. I usually run a F.D.R. between 3.0 to 3.45 depending on how tight and technical. Outdoors on big flowing tracks, I have been down in the 2.8s for f.d.r.
V8 Rumble likes this.
MidwestRacer is offline
Old 03-06-2023 | 10:25 AM
  #11525
TonysScrews's Avatar
Originally Posted by Kregger
Saw a post a couple weeks ago with a pic of a 3d printed device for cutting wheel wells on the car. Can't seem to find it and search isn't coming up with anything. I'm not even sure what thread it was in. Has anybody else seen this post and if so can you post the link.
Raceform makes a device to cut the wheel wells.
RACEFORM 1/10 PERFECT WHEEL ARC CUTTER (TC60-70)
TonysScrews is offline
Old 03-06-2023 | 06:05 PM
  #11526
Kregger's Avatar
Thanks. I have the olfa circle cutter that works fine for the actual cutting. I found the yeah racing wheel well marker, someone had it in their pit area when I was racing this past Sunday. Someone on RCtech did a 3d printed version of it and that's what I remember seeing. Thanks for the info though.
TonysScrews likes this.
Kregger is offline
Old 03-06-2023 | 06:30 PM
  #11527
I have the yeah racing one. It's nice, aluminum but the wheel arches are a bit tight, will body tuck if you don't cut extra off the back.
Xrayray is offline
Old 03-06-2023 | 07:19 PM
  #11528
jzone's Avatar
Thanks! greatly Appreciated!
jzone is offline
Old 03-06-2023 | 07:44 PM
  #11529
I had a friend 3D print up four of these. It works great because the tires sit on it and it lines up the arch perfectly. I mark it and cut out the wheel arches using small curved scissors.
https://www.thingiverse.com/thing:5401350
glennhl is online now
Old 03-07-2023 | 08:13 AM
  #11530
HenryC's Avatar
This has always worked well for me. I have had one of these for over 20 years. Only $7
Compass circle cutter
Silverbullet555 likes this.
HenryC is offline
Old 03-09-2023 | 05:19 PM
  #11531
RickSlick's Avatar
Have a touring car and looking for a thick lexan body for my Xpress car. Tired of just brushing the wall and tearing the body to shreds. Anyone know of a brand that makes thicker lexan bodies?
RickSlick is offline
Old 03-09-2023 | 05:28 PM
  #11532
Try some of the Tamiya bodies. Much thicker than aftermarket race shells.
angrymelon likes this.
pparrett is offline
Old 03-09-2023 | 07:27 PM
  #11533
RickSlick's Avatar
Thanks, going to check out,,,,,,,,,,,,
Old 03-10-2023 | 12:02 AM
  #11534
I just finished a Tamiya Mustang body. 141g with minimal paint and basic stickers. It has the rear wing and side mirrors plus the o rings and little clips.
Xrayray is offline
Old 03-10-2023 | 07:31 AM
  #11535
Default USGT Spec Motor FDR
At 3.45 to 3.85 stay on top of your motor temps. With up to 5 or 7 in a heat or main I like to have the giddy up at being around 3.85 - 4 to manage the infield as fast as I can. Guys we’re running 3-4 tenths faster laps in practice with a clear track but having to manage traffic the speed on the back straight was equalized with the giddy up I had in the infield.
chuck in indy is offline
