Like Tree2Likes
  • 1 Post By Roelof
  • 1 Post By Roelof
Max Power MP9
Old 07-10-2022 | 06:02 PM
speedracer1bp's Avatar
Default Max Power MP9
I have a max power phantom MP9 with a badly scratched piston I know they're Novarossi based I was wondering which one they were based off of I'm thinking it's a keep on. The motors were made several years ago like 2014 but has a nicely modded crankcase and a three tungsten weight crank. Would like to get it running again if anybody has any ideas as to what would fit.
speedracer1bp is offline
Old 07-11-2022 | 01:05 AM
Original MAX? MAX isn't out of business, high chance even the new AAC P/S set will fit.
But you have to look at the bore/stroke, Max engines ar so far I know always 16.2x16.8, the Keep-on will not work.
Roelof is offline
Old 07-11-2022 | 04:13 AM
My piston Mics out at 15.86 which is a long stroke I believe. My newer RP9 pistons are much larger and won't fit in the cylinder.
Old 07-11-2022 | 04:36 AM
Also the index pin in the case that aligns the cylinder is in the side, not at center of exhaust like RP9. I believe the keep on is on the side is why I thought they might work. I'm really looking for a P/S.
Old 07-11-2022 | 06:34 AM
You are right, it is an xtra long stroke, also recognized by the side center pin. The model was released 10 years ago...
Then you will come to indeed a Keep-on, Mesphito or Mito-9
davidl likes this.
Roelof is offline
Old 07-26-2022 | 09:34 AM
Would an Ison work?
Old 07-26-2022 | 10:29 AM
Old 07-26-2022 | 10:50 AM
No, the ISON is a normal long stroke (16.2 x 16.8)
davidl likes this.
Roelof is offline
Old 07-26-2022 | 10:36 PM
Gotcha! Thanks!
