Serpent srx4 gen3 >
Serpent srx4 gen3
Like Tree75Likes
Serpent srx4 gen3
Old 05-17-2022 | 08:36 AM
  #166
Default Thanks
Thanks. Works well. Can’t wait to get this car.
4wdfull is offline
Old 06-04-2022 | 05:34 PM
  #167
Default Front wheels?
What front wheels fit this wonderful car? SRX4 gen3
I've heard Associated wheels will fit, but looking on Amain there are wheels for B44, B64 and B74.
trying to find some pre-mount options....
brewkett is offline
Old 06-04-2022 | 07:23 PM
  #168
In my opinion, the Serpent wheel is the best option . The center bore for the wheel nut is recessed more than the AE b74.1 based wheel, on the rear its totally recessed.
savage24x likes this.
Raul Garcia is offline
Old 06-23-2022 | 07:14 PM
  #169
Default Titanium screw kit
Anyone have a link or source for a titanium screw kit for this car? I think Tworks has one. Was wondering if there were any others.
Also a pre-cut chassis protector?
4wdfull is offline
Old 06-24-2022 | 04:43 AM
  #170
BigRon's Avatar
https://rdt-products.com/product/chassis-specific-skin/
BigRon is offline
Old 06-24-2022 | 07:27 PM
  #171
Default traction rolling
I'm racing on indoor gray carpet medium to high traction and I'm having an issue on traction rolling on high speed turns (large sweeper off the straight)
I'm running Brian Hildebrand's setup from rug burn with the only change I'm using 1.8 front sway bar, and 1.5 rear sway bar, and 500cts shock oil front and back. Same Schumacher Cactus fusion 2 / cactus tires in yellow with blue tubby foam inserts. This is also a 13.5t car. Track favorite tire is the JC Fuzz Bites, going to try a set next race. Any ideas I can try to help on the traction rolling,
brewkett is offline
Old 06-24-2022 | 10:12 PM
  #172
personally I have limited gray carpet testing. If your flipping towards the tire being the issue. Glue the front outer flange /sidewall. Make sure the glue bead is ample. Personnel I use TLR Thin. You can also shave or clip the outside to 1/2 or ao to take away the front steering ..
Old 06-27-2022 | 09:44 AM
  #173
kufman's Avatar
How much ride height are you using?
kufman is offline
Old 06-27-2022 | 09:57 AM
  #174
savage24x's Avatar
https://sodialed.com/s/Ppr1
savage24x is offline
Old 06-28-2022 | 01:38 PM
  #175
I run on black CRC and had similar issues. Serpent now makes a 1.7 rear swaybar. Mine is currently still on the way, so I havent used it yet, but it should help alot.
Also Fuzz bites will offer significantly less side bite than the cactus which will help alot. I only use cactus when I want a really locked in rear end.
Also I'm not familiar with that setup, but also consider raising the rear inner pivot, that helped me alot as well.
BigRon likes this.
BHutch is offline
Old 06-28-2022 | 09:56 PM
  #176
Do you happen to know the part number for the 1.7 swaybar? Never mind, Found it SER500475
brewkett is offline
Old 06-28-2022 | 10:08 PM
  #177
This is my setup as I ran Tuesday night. I raised my front and rear roll center, fuzz bites front tires mounted for less traction, cactus rear. Still traction rolling but not as bad, short of trying to glue the side walls not sure what else to try.
Someone at the shop told me I should try softer front springs.....not sure as it goes against everything I know of for traction rolling.
File Type: pdf
brewkett is offline
Old 06-28-2022 | 10:54 PM
  #178
Brewkett,
Quickly glancing at your sheet. Id suggest:
both diffs with the "0" up giving the highest diff heights, laying the front shock inboard all the way on tower and outer front arm, rear shock 1 hole out on tower , and mid arm, move the rear hubs full forward, anti squat also will help with decreasing grip, move outer upper link outward(could also raise it for finer tuning). I'd also increase the front castor to the most allowed I think +5 is the most for the insert. But in my opinion download the "So Dialed" app, and the "So dialed Pill Calculator ". A lot of effort went into setting it up to help you with adjustments, and lots of info. Once using it , especially the pill calculator, you'll never use the editable sheets again.
Hopefully, I am helping your setup. Let me know if I can be more of assistance after changes made to the car. Have fun..
BigRon likes this.
Old 06-29-2022 | 09:52 AM
  #179
kufman's Avatar
CRC black carpet is strange stuff. I had big troubles with traction rolling when I first tried running sedans on it. What I did find is that stiffer and stiffer setups make it worse and more violent. It seems backwards, but the chassis does need to be able to roll into the corner some.
kufman is offline
Old 06-29-2022 | 02:11 PM
  #180
Originally Posted by Raul Garcia
Brewkett,
Playing with the pill calculator, would I be better with more anti squat, or more roll center?
brewkett is offline
