Like Tree396Likes
Tekno MT410
Old 09-14-2021 | 05:51 AM
  #2056
Jaypopsti's Avatar
I run a 2200kv castle MMX combo with a 16tooth and it’s controllable on 4s. No issues with drivetrain parts so far 👍
Jaypopsti is offline
Old 09-18-2021 | 07:09 PM
  #2057
Are the All Racing aluminum gearboxes worth the money? Do the stock plastic gearboxes break often? I am in the process of building up a super strong MT410 and want to get all the parts. Already have quite a few of the M2C parts.
CoryRC is offline
Old 09-19-2021 | 01:38 AM
  #2058
gavsta72's Avatar
Not sure if you mean the diff cases? but if you do....
The stock plastic are strong, there's guys running TP motors on 6S with no problems. The advantage of the M2C one's is the 50% more volume, and stronger of course, but the volume is the main thing imo. The stock plastic hold very little oil, it heats up quick, and i even opened them up after only a few runs once, and they were bone dry. It seems the oil evaperated
gavsta72 is offline
Old 09-19-2021 | 07:25 AM
  #2059
All Racing brand out of China makes front and rear aluminum gearboxes. They hold the diffs. They look very nice and are on e bay. They are around $200. Good to know about the diff cases though, I see Tekno makes steel ones now that hold more fluid, they might hold up better than the aluminum ones when a rock gets wedged in there as steel is harder than aluminum. The plastic ones do look rather small though. This build is getting expensive with all the upgrades.
CoryRC is offline
Old 09-23-2021 | 10:12 AM
  #2060
The price on the AllRacing gearboxes varies substantially on eBay ( ~145 to ~200 ). It would be nice if an M2C version was available.
Also, you may find the following threads by Overkill/0verkilll helpful.
AllRacing 7075 aluminum gearboxes!
https://www.teknoforums.com/threads/...gearboxes.821/
Building the ultimate monster truggy with Tekno & M2C
A collection of various MT410 links from post 2007 of this thread can be found at the following link.
Tekno MT410
CoryRC likes this.
Typpo is offline
Old 09-24-2021 | 08:09 PM
  #2061
Tekno MT410
Thank you Typo. I guess I’ll hold off on the AllRacing gearboxes for now and see how the stock ones hold up. Doing the M2C chassis and all the braces. Was going to add up all the $ for special parts I got so far, but rather not see the amount right now.
CoryRC is offline
Old 09-28-2021 | 06:10 PM
  #2062
What cst diff fluid is the best for all diffs? Will be running 4S battery with backflip LP wheels.
CoryRC is offline
Old 10-01-2021 | 11:41 AM
  #2063
What are the best bodies to use? Is the un breakable body from Russia any good?
CoryRC is offline
Old 10-07-2021 | 11:04 PM
  #2064
For completeness, the following post by Overkill on the Tekno Forums includes additional details about the AllRacing gearboxes.
Monster EB48.3 buggy
https://www.teknoforums.com/threads/...8-3-buggy.971/
Typpo is offline
Old 10-13-2021 | 11:31 AM
  #2065
So it seems the TKR 6051 shock pistons are sold out and discontinued. They are the 8x1.3 Cnc conical pistons. Going to run the orange springs with 800 oil, anybody know what pistons to get?
CoryRC is offline
Old 10-18-2021 | 11:58 AM
  #2066
Ackchyually's Avatar
Originally Posted by vettehigh
I upgraded to universal driveshafts (front/rear) and they are 0.35mm thicker than the cvj's. Also, some FlexyTub shock covers too. Took 10 days from Spain to get to me in NY. Went with Mugen Seiki because I used their oil
Could you please report back on the durability of those Flexytub shock covers? Also, do they work well? I am assuming you are NOT using the rubber gators underneath, is that correct?
I just got a Facebook ad on my feed, and my first impression is that it's a fantastic idea...as long as they work!
vettehigh likes this.
Ackchyually is offline
Old 11-18-2021 | 12:18 PM
  #2067
Default Diffs
What oil wt ct you guys are using in the F/C/R. 2200kv motor I’m running.
lighttravler is offline
Old 11-24-2021 | 01:44 PM
  #2068
RazorRC's Avatar
Tuning tips:
museguy likes this.
RazorRC is offline
Old 12-01-2021 | 07:27 AM
  #2069
Old 02-27-2022 | 10:44 AM
  #2070
I am a little confused on the correct orientation of which side the crown ring goes when putting the diff in the gear box/bulkhead. The manual shows on the right/passenger side. In all my other 1/8 cars it goes on the left. Not sure if this is an issue because you can simply reverse the motor if they spin wrong way.
CoryRC is offline
