Like Tree6Likes
  • 1 Post By gigaplex
  • 2 Post By Roelof
  • 2 Post By billdelong
  • 1 Post By billdelong
Electric problem
Old 02-07-2022 | 01:03 PM
Default Electric problem
Hello everyone,
I have a problem with the electronics of my 1/8 on road, the battery runs out very quickly, less than 1 hour. I currently use Sanwa M17 transmitter, 2 Sanwa PGS-XR2 servos, transponder and 1800mah lipo. I have tried a different transmitter and receiver and the problem is still there so I guess it will be a servo or transponder. Has anyone had a similar problem? Is there any way to detect which servo may be damaged?
Valerio is offline
Old 02-07-2022 | 05:29 PM
Originally Posted by Valerio
Hello everyone,
Are you having a problem with servo not working or running out of battery too soon? 1800mAh is a small battery for 1/8 car. You need something with more mAh.
Andy Koback is offline
Old 02-07-2022 | 08:11 PM
gigaplex's Avatar
And even then, don't expect to get an hour's runtime on a single battery.
Andy Koback likes this.
gigaplex is online now
Old 02-07-2022 | 11:15 PM
Thanks for the answers. The car is 1/8 on road nitro, the battery only powers the servos and transponder. Before having this problem I have done a semi of 20 min and a final of 45 with their respective warm-ups with the same battery. The servos work fine, but there is excessive consumption
Valerio is offline
Old 02-08-2022 | 02:42 AM
Check the end points. If a servo will lean on them it will draw more current.
Valerio and gigaplex like this.
Roelof is offline
Old 02-08-2022 | 03:10 AM
1/8 IC Fan's Avatar
Maybe a mod can move this...
1/8 IC Fan is offline
Old 02-08-2022 | 10:11 AM
How old is your battery?
If you're not getting the same run time that you used to get, the pack may need to be replaced.
A good way to check the health of your cells is to get IR readings when the pack is new and when the IR fades, then the cells are going to lose capacity and will need to be replaced.
Andy Koback and Valerio like this.
billdelong is offline
Old 02-09-2022 | 12:30 AM
The endpoints are correct and the batteries are new. Before I used 1400mah batteries and due to this problem I have bought two 1800mah batteries and it fails with both batteries.
I have tried to measure the consumption with an ammeter and the consumption at rest is around 0.15A and exerting force on the car I get to have peaks of 0.6A, so with a 1800mah battery the autonomy should be greater than 1,5 hours
Valerio is offline
Old 02-09-2022 | 01:53 AM
the rc guy's Avatar
could be just cheap batteries.
the rc guy is offline
Old 02-09-2022 | 02:25 AM
And the brake, not adjusted to full blocking?
Maybe you schould mount a current meter between the battery and the electronics and measure the current in differen situations and configurations. And do a charge/discharge cycle on the battery if it has the noticed capacity.
Roelof is offline
Old 02-09-2022 | 03:32 AM
the rc guy's Avatar
your #;s are wrong .6 amps thats not possible with a steering servo
Old 02-09-2022 | 03:35 AM
gigaplex's Avatar
How is that not possible?
Old 02-09-2022 | 03:54 AM
The batteries are Arrowmax and Sunpadow brand, I donīt consider them to be cheap batteries.
As for the linkage, everything is well adjusted, I don't have much brake, the direction doesn't stop and the carburetor opens just enough.
I suspect a bad servo but it works fine
Valerio is offline
Old 02-09-2022 | 07:27 AM
I agree that it might be the servo, but have you removed the servo horn and verified no binding in any of the steering links? Sometimes the plastic goes out of round and I have to pinch the ball ends with pliers to relieve pressure on the links so they turn butter smooth, you might be losing efficiency there possibly. If the links are good, then it wouldn't hurt to rebuild the gear box on the servo as well, flush all the old grease on the gears while inspecting for any broken teeth that might be binding inside the servo, then apply fresh white lithium grease to rejuvenate your servo efficiency again.
Valerio likes this.
