Team Yokomo YZ2 CAL3.1 / DTM3.1 / SO 1.0 >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree133Likes
Last edit by:
Print Wikipost
Old 12-13-2021 | 10:08 AM
  #46
Cain's Avatar
Something I am wondering for your guys with your 3.1s to watch for as I have a CAL3.05 for a lack of a better term, basically converted a good portion of the rear end over to the new specs, mainly to save on parts to carry around with the daughter when she gets my car.
Anyway, I noticed at my last race and prior to this past weekend I had something weird going on in the rear end, and it looks like the screws that go through the diff cover had pulled threw on one side. As we are not using that brace setup anymore on the 3.1s, may be worth watching for. I ended up putting locknuts and running slightly longer screws all the way through for a more secure fit.
Cain is offline
Old 12-14-2021 | 09:04 AM
  #47
Tim W.'s Avatar
Can't wait to get the Cal 3.1! Hurry up January!
Cain likes this.
Tim W. is offline
Old 12-21-2021 | 01:02 AM
  #48
lexusbest's Avatar
Originally Posted by Will27
If you put these bumpsteer shims underneath the steering rack instead of above it resolves this problem, or at least makes it much better. It gives more clearance between the ballcup and the bellcrank at full lock. Just increase the shims at the outer steering ballstud by 1mm to make the bumpsteer the same as before. You can also leave them out completely, but you'd have to swap to shorter screws at the same time or they can stick through too much and touch the servo linkage when turning right.
This is interesting. I grinded a bit both plastic ballcups to archieve full lock, but this is a more elegant fix. Will check that when my cal3.1 arrives and add the tip to the wiki if necessary
Will27 likes this.
lexusbest is offline
Old 12-21-2021 | 01:06 AM
  #49
lexusbest's Avatar
I cut the rear brace in m cal3 and had no issues
Cain likes this.
Old 12-21-2021 | 09:40 AM
  #50
Cain's Avatar
like i said, something to watch for since we are cutting down on some of the bracing in that area and relying on the plastic mount. may be worth having that mount as a spare in the box.
DTM3.1s showing in stock at amain!
Cain is offline
Old 12-23-2021 | 01:29 PM
  #51
lexusbest's Avatar
https://teamyokomo.com/downloadfiles...ion_Manual.pdf
Cal3.1 manual is up.
Showing 4.3mm rear hexes and 2x1.8 rear pistons. Time to order those new 1.7s
Cain likes this.
Old 12-25-2021 | 06:03 PM
  #52
Cain's Avatar
yeah looks like same pistons front and rear from CAL3 and DTM3, respectively.
Here is the setup sheet:
https://site.petitrc.com/setup/yokom...NvZ4YhbvZEi2wM
Cain is offline
Old 12-25-2021 | 10:11 PM
  #53
Looking at the manual for the CAL 3.1, the front is where they added length to it. If you compare the front pockets under the servo from the CAL3 to the 3.1 you can see there is a difference.
F1nalized is offline
Old 01-19-2022 | 01:27 AM
  #54
lexusbest's Avatar
I would like to give some note here. Cal3.1 rear shock bodies are slightly longer.
Cain likes this.
Old 01-19-2022 | 01:33 AM
  #55
lexusbest's Avatar
And some more building notes here for people who are new to the platform.
  • You will see a pair of shims left when building differential. Those shims are used for removing play in front hex axle. Be carefull when installing it. The shim fits right in the gap between the bearing and the extra axle lenght. Screw in carefuly making sure that the shim doesn't move.
  • Similar situation happens with steering rack shims. Those shims fits right in the gap, make sure they do not move when screwing in. If those shims are not correctly placed, steering rack will have too much play.
Cain likes this.
Old 01-19-2022 | 07:31 AM
  #56
Cain's Avatar
how is the rear hub carrier play when mounted up in the rear a-arm?
Cain is offline
Old 01-19-2022 | 10:00 AM
  #57
I'd think if Yokomo wanted us to shim the front axle, they would've included it in the manual...As they did with the rear axle...And to note, those "extra" shims don't even come with the DTM3.1...
jbirdsrc is offline
Old 01-19-2022 | 02:25 PM
  #58
lexusbest's Avatar
Will check that tomorrow, i can't tell you exactly right now. Build finished.
Cain likes this.
Old 01-19-2022 | 05:21 PM
  #59
Cain's Avatar
looks great, whats her fighting weight in grams RTR with tires and body?
lexusbest likes this.
Cain is offline
Old 01-24-2022 | 04:09 PM
  #60
RazorRC's Avatar
Had to find out what all the fuss was about!
Cain, thecman26 and lexusbest like this.
RazorRC is offline
