Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 12-14-2021 | 08:18 AM
  #10876
MikeR's Avatar
Originally Posted by Xrayray
Hi Mike, I was referring to your advice a couple months back. I am using a fresh chassis plate and I do not have any side scrapes on it after a few race days. I have the shocks standing up, with stiffer springs as well.
I did have the issue of the tire being unglued last time I was at Cal, but they have been always glued/checked since then. I usually would get snap oversteer going into a sweeper at the end of the straight if I didn't glue them up.
At the last Turkey Race in Santee (generously sprayed), I started the day practicing on balloons but ended up on new tires for the rest of the day. My new USGT tires were about the same as 36 GQ slicks.
Its hard to explain but the old set feels numb and not as responsive. I did, however, see that sweepers or constant load corners were good, but 180 turns and direction changes were not.
For sauce, I use SXT max 3.0 and tire warmers around 60 deg C.
That's why I highlighted 'carpet sauces'- SXT 3.0 is an awesome carpet sauce but is like wax for asphalt Get you some FXII and it should be a lot better. Try and clean off the old SXT before you race again also but hopefully the SXT isn't forever absorbed into your older tires...
OSherman, V8 Rumble and Xrayray like this.
MikeR is offline
Old 12-14-2021 | 09:13 AM
  #10877
MikeR's Avatar
Something else to look at is make sure your ballooned tires are not rubbing your wheel wells.
MikeR is offline
Old 12-14-2021 | 10:47 AM
  #10878
Thank you, I'll try FXII. I had no idea SXT is a carpet sauce. Wheel wells do not have any rubs yet.
MikeR likes this.
Xrayray is offline
Old 12-14-2021 | 11:51 AM
  #10879
Dan's Avatar
Dan
I'm doing a new program for asphalt racers. Give me your new sets so I can run them on carpet. Once they start ballooning, I will ship it to you, ready to use on asphalt.
robk, Raman, NutDriver and 2 others like this.
Dan is offline
Old 12-14-2021 | 12:17 PM
  #10880
Lol I'll just send you my SXT
Xrayray is offline
Old 12-14-2021 | 12:59 PM
  #10881
Raman's Avatar
I think it’s time we all switch to the belted version they made for the FF cars.
Raman is offline
Old 12-14-2021 | 01:12 PM
  #10882
robk's Avatar
2:???
3: PROFIT!
Rick Vessell likes this.
robk is offline
Old 12-14-2021 | 02:53 PM
  #10883
Raman's Avatar
Brilliant 😂
Raman is offline
Old 12-16-2021 | 03:25 PM
  #10884
This is spot on!
dman18t is offline
Old 12-16-2021 | 03:57 PM
  #10885
Where do you get these belted tires? I looked at Gravity and didn't see them.
glennhl is offline
Old 12-16-2021 | 04:30 PM
  #10886
NutDriver's Avatar
I have seen them at Monaco RC. They are the spec tire for FWD in the ETS races, I believe.
glennhl likes this.
NutDriver is offline
Old 12-16-2021 | 04:44 PM
  #10887
These?
https://www.monacorc.com/us_en/hudy-...right-left-2-2
EDIT: I found the ETS rules, the allowed tire for FWD is Ride Belted RI-26073.
https://www.michaelsrchobbies.com/ri...on-silver.html
glennhl is offline
Old 12-16-2021 | 06:22 PM
  #10888
NutDriver's Avatar
These:
https://www.monacorc.com/us_en/26073...e-wheel-grey-4
Old 12-18-2021 | 05:26 PM
  #10889
OK, my car was perfect a few weeks ago, but last week it started getting loose and today it was worse. I keep track of my tire usage and I'm pretty sure these tires had over 30 five minute runs on them. What kind of tire life has other people gotten on very smooth asphalt? Thanks, Glenn
glennhl is offline
Old 12-18-2021 | 06:14 PM
  #10890
Try it like it is and with new ones on the back only. You'll get your answer
glennhl likes this.
Racermac73 is offline
