Schumacher Eclipse 4 >
Like Tree138Likes
Old 09-26-2021 | 04:37 AM
  #76
choisan's Avatar
Originally Posted by Quante
Hi guys, love the car and I'm thinking of swapping brands but the specialised wheels are a turnoff.
Any idea if an xray axle setup would fit? Got a few of those...
Thx
i would say it is
Quante likes this.
choisan is online now
Old 09-26-2021 | 12:27 PM
  #77
Thx
At our track, the spec tire from Contact that fits the hex axle works just as well as the CRC tire and is cheaper. I like the easier tire changes with the single wheel nut vs 3 screws. However, you can get the 3 hole hubs from Schumacher if you want to use those style wheels. I have both. I use the contact tires with the hex when possible and the 3 hole hubs when necessary.
Rick Vessell and bshookup like this.
0010 is offline
Old 09-26-2021 | 08:57 PM
  #78
Hugh Jazz's Avatar
Originally Posted by choisan
i would say it is
Yes it does. Just requires a different spacing on the axle to get it centred properly.
Hugh Jazz is offline
Old 09-27-2021 | 01:17 AM
  #79
I understand, but at least I get to run the sets I still have 😁.
I saw the spec tire was fairly cheap, still gotta look into those. I have to say, the problem I find with 1/12th is the huge choice of tires and compounds.
Spec tire always looked like a great idea to me.
Quante is offline
Old 09-27-2021 | 01:20 AM
  #80
Aah thats no problem at all, I even drove my old R12 axle setup on the xray for some time because I still had like 20 sets to burn.
But with xray you never know 😁. Their sidelinks are even not quite the same as the other brands so you can only use theirs...
Quante is offline
Old 09-27-2021 | 01:46 AM
  #81
Btw, how do the damper tubes as central damper hold up? Redo them once a day or something like that?
Quante is offline
Old 09-29-2021 | 07:10 PM
  #82
MikeO's Avatar
I can't honestly say, I've been trying set up on the center tube so I can't give an accurate maintenance run down. I like to keep them clean to so I at least redo them every track day. Takes no time at all. Gives me something to do in the pits besides shoot the ----
MikeO is offline
Old 09-29-2021 | 08:30 PM
  #83
Dan's Avatar
Dan
On my Icon I do it every other race but run very thick oil. Its fairly quick to do, love how fairly low maintenance it is. I imagine it wouldn't hurt to do it every race on the Eclipse to keep the handling consistent.
Dan is offline
Old 09-29-2021 | 11:39 PM
  #84
MikeO's Avatar
I’ve been messing with 5k-15k. Thinner it gets the more it’s gonna leak. Still beats having a shock 🤷‍♂️
MikeO is offline
Old 09-30-2021 | 10:53 AM
  #85
Are these the ones with the green stripe?? Price is awesome...
Quante is offline
Old 09-30-2021 | 12:30 PM
  #86
The ones we have are the purple stripe. I think that is what is referred to as the US Spec tire. Our LHS sells them for about 12.50 a pair. $25 is not too bad for a set.
0010 is offline
Old 09-30-2021 | 12:33 PM
  #87
Dan's Avatar
Dan
Can confirm the purple stripe Contacts work good and the price is awesome. I don't think I am a good enough driver to truly tell if they are about same as the CRC purple stripe. Need more run time.
Dan is offline
Old 09-30-2021 | 12:38 PM
  #88
Green stripes are GT12 - the real European GT12 with the narrow rear tires, not the American bastardized version of GT12.
Purple stripes (or blue stripe JFT) are the spec tire almost everywhere in the US for all 1/12th scale classes, except modified. Contact's version of the purple stripe tire is the best value. DiscountRCstore.com sells full sets for a little over $16.00. racing-cars.com may be a little less expensive after currency conversion, but they have been out of stock for a while.
biz77 is offline
Old 09-30-2021 | 02:13 PM
  #89
patorz31's Avatar
The purple strip is exactly the same as the crc ones.
I had the prototype ones, almost three years ago and we tested them back to back with the crc's lap times were consistant. I gave a couple of sets to the bigger Northwest 12th scale drivers to take home and try. Slapmaster had a set or 2. He confirmed our testing we did here in Canada. The only difference was the rim softer at the time.
Update just rechecked Brian's email he whished the wheel was a little softer then it was.
patorz31 is offline
Old 09-30-2021 | 02:36 PM
  #90
MikeO's Avatar
Anybody seen the bare hex wheels in stock state side? Schumacher is out of stock on them. Wanna see about prepping for some open tire races. Would like to possibly mount some Ulti’s, Bomber and Yoke foam.
MikeO is offline
