Schumacher Eclipse 4 >
Like Tree138Likes
Old 10-02-2021 | 04:59 AM
  #91
What oil thicknesses for tuning are recommended to have for the damper tubes and front kingpins?
Using an assortment from windtunnel over the past 15 years but they wont say how much k they are...
Just need to invest in some other oils so I can follow setup sheets better.
Thx
Quante is offline
Old 10-03-2021 | 09:10 PM
  #92
Thx
We have gone as high as 50k on the center tube on medium grip black carpet. Side Tubes in the 10k-50k. For front King Pins, it is a very minor adjustment to me, but I thunk I am running around 7k on the front.
Rick Vessell and Quante like this.
0010 is offline
Old 10-04-2021 | 10:12 AM
  #93
G-rem's Avatar
Hi !
I have a question regarding the mass damper #U8137 set : can someone please tell me the diameter of the 12g mass and the one of the 23g mass ? Also, I would like to know what is the length of the shaft, please.
Thanks for helping,
G-rem
G-rem is offline
Old 10-06-2021 | 05:54 AM
  #94
Hi guys,
finished assembling the car. The rear end feels really smooth but I cant say the steering blocks slide very nice over the kingpins.
Do you all do an extra polishing step??
Also, how do you add oil to the front kingpin? Just fill up the center? I really feel the block sticking onto the bottom because of the oil.
Quante is offline
Old 10-06-2021 | 09:08 AM
  #95
cementsurfer86's Avatar
Hey all,
Does anyone on here have a good starting setup for US-spec GT12? This is with the SJT rubber tires, for reference.
We're starting a class at our local club and I'm looking for ideas. Thanks in advance!
cementsurfer86 is offline
Old 10-06-2021 | 08:13 PM
  #96
Hi guys,
I did not do any polishing but they do wear in with a little use. As for oil in the kingpin you just go through the center until a little bit comes out. The bottom doesn't stick after a while of use and then the knuckles are worn in.
Jon
Quante likes this.
Juniorabca is offline
Old 10-09-2021 | 12:18 AM
  #97
Originally Posted by G-rem
Hi !
Thanks for helping,
G-rem
the shaft is 23.5mm length
the 23g is 19mm OD
i dont seem to have the 12g near me unfortunately but its the same height and maybe 14mm od if i had to guess?
G-rem likes this.
Brian Bosley is offline
Old 10-09-2021 | 01:05 AM
  #98
G-rem's Avatar
the 23g is 19mm OD
Many, many thanks for the info !!
Cheers,
G-rem
G-rem is offline
Old 10-18-2021 | 10:23 AM
  #99
Hi guys,
ran the car for the first time last friday and it drove pretty good for the first time out ☺️
​​​​​​ 2 year of not driving 12th has left its mark though so I ordered a 17.5 to replace the current 13.5 😉
Brian Bosley likes this.
Quante is offline
Old 10-19-2021 | 07:05 AM
  #100
clinttredway's Avatar
Getting my E4 ready for practice tomorrow
qcrc, Buckland, Poor_Boy and 3 others like this.
clinttredway is online now
Old 10-24-2021 | 04:51 PM
  #101
TonyD.'s Avatar
do I need to change anything on the Eclipse 4 to run it in GT12 class?
TonyD. is offline
Old 10-24-2021 | 06:49 PM
  #102
Dan's Avatar
Dan
Maybe a ball diff depending on track conditions. And different camber plate.
Dan is offline
Old 10-31-2021 | 09:30 PM
  #103
Just finished putting my E4 together and tried running on the street outside my house (I will be running on an asphalt track) - a few challenges surfaced I was hoping to get some suggestions on.
Setup is per kit with:
  • 4 degrees caster
  • No front droop shims - gives me ~0.5mm droop
  • 4.25mm front, 4.75mm rear ride height
  • Contact LMP Purple Stripe spec tire, 43mm F/R
  • Battery at +1 from full rear position
  • 13.5 motor, 84 rollout
Issues:
  1. When lightly accelerating in a straight line, the car pulls to the left, even when adding throttle very gradually. When holding speed, it tracks straight, so is not a trim adjustment.
    • Setting side springs - right side spring is a half turn in to get both front tires lifting off at the same time
    • If I instead add preload to the left side spring, I can get the left pull to go away, but then there is tweak as front left tire lifts way early and rear pod is obviously tilted left at full droop
    • Things I have checked:
      • Chassis has no rocking when put on a flat plate so doesn't appear to have tweak
      • Camber is the same each side
      • Car is balanced left to right
      • Swapping tires side to side - no change
  2. Accelerating from a turn, it pirouettes extremely easily around the inside front tire (left or right turns)
    • My street is low traction, but my F1 car (ball diff, Gravity tires) does fine
    • I figure the spool is making this worse, and likely whatever is causing the left pull issue above.
Any suggestions?
m59y is offline
Old 10-31-2021 | 11:17 PM
  #104
  • 4 degrees caster
Issues:
Any suggestions?
Foam tires on a non prepped surface get hardly any traction so that will have you chasing ghosts that won’t happen once you get on a racing surface. You will want a ball diff for asphalt racing unless running on a super high bite track or the spool will make the car push something fierce
lk2849 is offline
Old 11-03-2021 | 07:49 AM
  #105
Thanks. I knew the traction would be low, just didn't think it would be that bad! Will hopefully get to a practice session soon to see how it does.
m59y is offline
