TAMIYA M-06 Thread >
TAMIYA M-06 Thread
Like Tree121Likes
TAMIYA M-06 Thread
Old 02-23-2021 | 05:16 PM
  #2341
Originally Posted by TRFHORNET
item 92237 and 54267 are the same except for the colours, dimension etc are all identical.
what exactly do you mean by installing shims between the hub and upright, the hub and the upright is the same thing so im not sure what you mean.
i believe the issue is the bearing fit into the alu upright, its not firm, infact if you place the bearings in and pick the upright up without the axle installed they will fall out, inside and outside
so im pretty sure this is where the free play is coming from, ive tried brand new 1050 bearings from Tamiya and also Xray. the issue is still the same, even if i shim inside the upright between
the 2 bearings on the axle the issue still remains.
Hello
The Hub and the Upright are two different parts; (look-up: Tamiya Hub - and Tamiya Upright).
I installed DuraTrax Bearings in the Rear-Uprights of my M-06.
-I removed the bearings then cleaned the Rear-Uprights inside and out.
-They are Really a Bit loose in the Upright; but they Won't fall out.
(Correction: I Didn't install Shims between the Hub and Rear-Uprights). . . neglected-Chassis; I forget/forgot about it.
It just Could be the bearings you chose are a super-fraction too small. . .or the Anodizing of the Blue Rear-Uprights adds a super-fraction of a difference over the Silver Rear-Uprights (?)
Good luck
Stay well
Take care
GuyIsDamGood is offline
Old 03-01-2021 | 02:03 PM
  #2342
monkeyracing's Avatar
I’ve seen bearings loosen up if the upright is old or has a load of use. Sometimes, (rarely) cheaper bearings can be very slightly out of spec.
monkeyracing is offline
Old 03-02-2021 | 12:22 PM
  #2343
Hello
You could have a point.
I originally purchased the M-06 for my kids. They basically lost interest for the R.C. Hobby; so I don't want to invest too much money on the chassis. That's the reason for the low-budget DuraTrax Bearings.
Stay well
Take care
Old 04-20-2021 | 01:48 PM
  #2344
pep
Hello everybody! recently bought a m07, I love it. But I am attracted to rwd ..... And I have doubts .... I am not going to compete in races, I have them to use at home, in the yard, or in the garage.
My question is ... buy an M06 kit with shock absorbers and bearings, or go for an m08 ...
What can you tell me?
Thanks!
pep is offline
Old 04-20-2021 | 10:08 PM
  #2345
angrymelon's Avatar
Thanks!
I own both but haven't raced either yet, but I can say the M08 is much more race oriented. If you're going to run on irregular surfaces or some offroad, I'd go with the m06. I even built an M06RA for bonus ground clearance
Tamiya M06RA with Escort Mk2 body.
GuyIsDamGood, Raman and ruebiracer like this.
angrymelon is offline
Old 04-21-2021 | 01:53 AM
  #2346
pep
Oh! that body looks impressive!
one question ... what chassis size is best for the m06? 210/225/239?
Thanks again
pep is offline
Old 04-21-2021 | 07:22 AM
  #2347
Thanks again
Generally, for racing, people go for longer chassis as that makes the car more stable. That said... none is "best". I'ts a question of what fits your body.
GuyIsDamGood and ruebiracer like this.
Nerobro is offline
Old 04-21-2021 | 07:46 AM
  #2348
Raman's Avatar
I picked up the same body as well. What livery are you going to paint?
ps.. what are the red uprights in front and rear?
Raman is offline
Old 04-21-2021 | 07:48 AM
  #2349
Raman's Avatar
Long chassis is good for FWD.. for rear wheel drive, I personally think 210/225 is better... keeping in mind that these cars don’t have much top end speed to have stability concerns.
ruebiracer likes this.
Raman is offline
Old 04-21-2021 | 08:12 AM
  #2350
angrymelon's Avatar
I haven't decided yet on the livery. I've been looking at a few UK based decal sellers, but can't decide
The red uprights are from the MF01X platform. They're actually just red versions of the uprights that come with the M05RA, but those are much harder to locate. If you're not familiar, they have a lower and upper mounting hole, so you can get a bit more ground clearance just by how you install them. Similar to the design of the TT02.
Old 08-06-2021 | 11:56 AM
  #2351
Raman's Avatar
New M06 kit coming
58698 Lotus Europa Special M06 Chassis
Raman is offline
Old 09-14-2021 | 12:40 PM
  #2352
New M06 kit coming
Josh...aka Harley Designs on YouTube...was just talking about this in his weekly "Scale News Update". While he's primarily a crawler guy, he does cover other aspects (even FE boat releases, once in a rare while) of RC.
I'm not new to RC (read my 'signature', and you'll know), but I am EXTREMELY new to Tamiya kits...as in, I haven't even built any...yet. My stepdad, who has 2 RCs (Traxxas 2WD Slash, and ProBoat Recoil 17), is ready to build his first kit...so, I picked up two (different) TT-02s for us to build side-by-side over Thanksgiving week. And, before anyone says anything, yes, certain upgrade parts (oil-filled shocks...oops, excuse me...dampers, bearings, etc) have already been purchased...tho, mine will be getting more than his, as I plan on seeing how it handles in USGT.
Anyway...having seen Josh cover this upcoming release, I got excited. The Europa has always been one of my two favorites from Lotus (the Esprit, partially in thanks to "The Spy Who Loved Me", is the other), so it should be obvious why I was excited. However, I know nothing about the M-06 chassis, especially the M-06RR the Europa will be released on.
I get that, like the 1:1 car, it's RWD w/ a rear engine (ok, technically, the real cat is mid-engine, but close enough for government work). I get that the kit uses a double-wishbone suspension. And...that's all I know. I don't care how easy/difficult the build is (those who read my 'signature' know I've built far more complex vehicles). I don't care about is ability to be raced (it wouldn't be...it would be just for fun, VERY light bashing). What I'm interested in knowing is, in regards to the M-06RR chassis, how does it handle? Is it ready, or hard, to drive? On a 0-10 scale, would it be considered a '0' (ie. "best avoided"), a '10' (ie. "absolute must-have"), or somewhere in-between?
Lastly, if I decide to get the Europa, I have a few questions regarding 'Hop-Ups'. which parts would be an absolute necessity (ie. "level 1" upgrades)? Which would be 'highly recommended' (ie. "level 2"). And, which would be "suggested, but not level 1 or 2 upgrades (ie. "level 3)? Also, what upgrades parts (is any) should be avoided and/or are completely unnecessary (ie. a waste of money and/or realistically useless)? The reason for these questions is, primarily, because I don't know anything about the different M-06 variants...but, also because, in general, I don't know anything about the M-06 chassis. Would greatly appreciate any, and all, 'helpful' input.
Panther6834 is offline
Old 09-14-2021 | 12:50 PM
  #2353
Raman's Avatar
I have a special fondness for the M06 as I raced it for close to a decade. It is a quirky chassis, basically a buggy layout for on road. It can be made to work and fun to drive on high traction surface, but in comparison to the current M07/M08 it’s a heavy pig and doesn’t have the same top end speed due to gearing.
So if you plan on tracking the car for competition, I’d recommend the M08 with the Lotus body set when it becomes available separately.
If that is not an option and you decide to stick with the M06, I recommend upgrade dampers to basic kit and that’s it. It’s all you need. The rest is more for bling
jlm70 likes this.
Raman is offline
Old 09-14-2021 | 01:17 PM
  #2354
While I could, POTENTIALLY, put it on the track...again, IF I get it...it would definitely NOT be for racing - it would be purely for my own enjoyment (say, during practice, or 'open', track time). The TT-02 will be for racing (NOT that I'd expect to win, or even 'place', especially considering what chassis most other USGT racers are running)...but, again, primarily for fun.
I'm primarily interested in knowing how well (or horribly) the M-05RR chassis handles, and whether the chassis is easy, or difficult, to control. I have (for off-road racing) 2WD vehicles off-road vehicles (1/10 XRAY buggy & TLR truggy), and I know how they drive/handle...but, one cannot compare 2WD off-road vehicles against a RWD on-road vehicle (even if having expedience in both). I might not have any clue how a RWD on-road vehicle is supposed to handle/behave, but I do know it would be different than a 2WD off-road vehicle. So, that is the primary purpose behind the first questions I asked. As for the 'upgrade' questions, those area things I always ask when getting into a new "classification" of vehicles...it's good/smart knowledge to have.
kajex7 likes this.
Old 09-14-2021 | 02:45 PM
  #2355
Raman's Avatar
I do not have kind words for M05 for FWD. I find them full. They just spin tyres and go and under steer. RWD takes finesse and the M06 will require a lot of that + patience. You can’t tap the brakes or it will swap ends, plain and simple.
I’ve ran an M05 and M06 in my cul de sac and the M06 always brings a smile to my face.
GuyIsDamGood and jlm70 like this.
Raman is offline
