Like Tree2991Likes
1/12 forum
Old 06-29-2021 | 09:09 AM
  #48886
MC Hamilton's Avatar
I see alot of people around the midwest running the Protoform Strakka and CRC Black Art BA009. I usually run the light weight versions instead of the super light weight. The Black Art body that I just bought is listed as light weight, but is considerably thinner than the Strakka light weight - like 38 grams vs. 45 grams. I also just bought the Bitty Design BDY12-RBX to try. It looks so much better than the other bodies. Painted it, but haven't tried it yet. It is a little heavier than the Strakka - like 48 grams. If I was to order this body again, I might go with the super light weight.
silden likes this.
MC Hamilton is offline
Old 07-01-2021 | 08:08 PM
  #48887
I really like the Bitty Design LSM19 or the Montech M20. A couple of guys have tried the Robox and really like it. One had been running the CRC Black Art for years and likes the way the Robox drives. That is what I will try next.
0010 is offline
Old 07-02-2021 | 09:04 AM
  #48888
Bsthetech's Avatar
I count the life of my bodies in laps...I grab whatever is cheapest
Bsthetech is offline
Old 07-06-2021 | 04:14 PM
  #48889
New to RC stuff and this forum but I am sure there are some that know this thread is 20 years old next month. First post 21st August 2001.
Munchens is offline
Old 07-06-2021 | 05:14 PM
  #48890
Curious...anyone on here used the VSS front end kit on the crc?
phatboislim is offline
Old 07-06-2021 | 08:30 PM
  #48891
gubbs3's Avatar
Issues I've had with CRC front ends: Pivot ball not threading straight, binding/loose lower pivot ball, some of the molds way out of spec and balancing caster left/right is full forward on one side and full rear on the other. Main screw direct thread to plastic... Its fine really. Tap the threads and it should be good to go. Genesis RC kit with a nut also.
VSS: Tight tolerances, hard/std option for tuning or durability, width adjustable, less thread in parts that walk out and tweak, easy camber gain adjustment.
Both are good front ends. There's just more you can do with the VSS if you know what you're doing. And if you don't there's less to get wrong.
gubbs3 is offline
Old 07-06-2021 | 08:35 PM
  #48892
gubbs3's Avatar
Next year I'll buy it a drink.
Racermac73 and JeffofSpace like this.
gubbs3 is offline
Old 07-07-2021 | 01:45 AM
  #48893
I know it'd be a learning curve for me to figure out the VSS, I guess my biggest question is does it generate more entry steering than the classic crc front end. On a small track I've seen the difference between my car and others that the entry in my crc is lacking. This is after yrs of owning and loving my crc. Now that I'm trying to elevate to compete with some of the faster folks I see where my car is lacking. I honestly don't want to leave crc for xray because all xray does is release a new $400 12th scale every yr and I'm not tryna start that money pit
Old 07-07-2021 | 04:49 AM
  #48894
Originally Posted by phatboislim;[url=tel:15802993
15802993[/url]]I know it'd be a learning curve for me to figure out the VSS, I guess my biggest question is does it generate more entry steering than the classic crc front end. On a small track I've seen the difference between my car and others that the entry in my crc is lacking. This is after yrs of owning and loving my crc. Now that I'm trying to elevate to compete with some of the faster folks I see where my car is lacking. I honestly don't want to leave crc for xray because all xray does is release a new $400 12th scale every yr and I'm not tryna start that money pit
I agree on this statement only thing is the CK25 is probably at it’s life cycle. It’s been out a couple years and the only reason I haven’t taken the plunge.
performula is offline
Old 07-07-2021 | 05:34 AM
  #48895
Get the tie rods higher on the steering block and lower on the servo saver, that will get the steering you are looking for. Otherwise it creates toe in as the front of the car travels which loses steering, creates scrub, and loses corner speed. Just my 2 cents
Racermac73 is offline
Old 07-07-2021 | 05:36 AM
  #48896
Removing weight from the front of your car will make it turn.
ckrell is offline
Old 07-07-2021 | 05:46 AM
  #48897
Default CK25
I agree the CRC has had a long life, but still a leader of the pack locally. No issues with my CK25 when a good driver has it. The owner of our indoor track has xrays and says the 1/12 scale xray has a pos front end designed like the eclipse and legends front steering blocks. True dat. Crunchy in the beginning of the stroke and can bind up in a turn.
Almost is offline
Old 07-07-2021 | 07:04 AM
  #48898
Dan's Avatar
Dan
I don't see why it should matter if Xray is releasing a new kit every year. Not like the prior year model goes immediately obsolete. Xray only does very minor annual updates and do big changes every once in a while (like the '21).
The CK25 is inexpensive and still works well at the club level box stock. With that said, rumors is that CRC is working on something new.
simple likes this.
Dan is offline
Old 07-07-2021 | 12:35 PM
  #48899
DesertRat's Avatar
I would hope for a lightweight pod plate design, without the slider. Something a bit like the old TOP Rebel had, but a bit stronger.
silden likes this.
DesertRat is offline
Old 07-07-2021 | 02:03 PM
  #48900
hanulec's Avatar
sounds like a roche car
RacinJ, DesertRat and Racermac73 like this.
hanulec is offline
