Like Tree12Likes
Tekno NB48
Old 05-23-2021 | 05:30 PM
  #3481
No set formula for clutch shimming. Have to adjust for alignment like you said and to keep the bell off the flywheel and make sure shoes are engaging properly like I said before. You want a very small amount of play. I’d run the washer for the screw that hold the clutch bell on if you can.
cjtamu is offline
Old 05-25-2021 | 06:40 AM
  #3482
Has anyone installed the Fioroni differential cases? They’re aluminum.
LoudOne is offline
Old 11-27-2021 | 11:29 AM
  #3483
What the pros and cons of the nb48 2.0 ?
what it does good and bad ?
bumpy or smooth track ?
thanks
kahuna2793 is offline
Old 06-17-2022 | 07:36 AM
  #3484
Default Hi there
thanks
To me it does everything well very easy to drive especially not being the best driver handles the bumps great and smooth tracks and it flies and jumps well to I'm coming from a tlr 4.0 buggy and kyosho mp9 tki 4 tlr was nitro the other electric hope this helps
Bigv is offline
Old 06-27-2022 | 08:01 PM
  #3485
crydaddy's Avatar
Fixed.....
crydaddy is offline
Old 07-17-2022 | 07:48 AM
  #3486
Confusedrcracer's Avatar
Default Prototype carriers...
Prototype or pre release... either way, looks like they have figured out the king pin screw issue and beefed up one of the parts that can change your hub angle with a single part..
petersen114 likes this.
Confusedrcracer is offline
Old 07-22-2022 | 09:17 AM
  #3487
petersen114's Avatar
Fixing the kingpin issue would be nice. Moving the engine more forward so different clutches can be used would be even better.
petersen114 is offline
Old 07-27-2022 | 11:53 AM
  #3488
Tekno has finally released all the info on the new NB48 2.1. https://blog.teknorc.com/2022/07/27/...tro-buggy-kit/
Cain likes this.
MX304 is offline
Old 07-27-2022 | 06:09 PM
  #3489
frewster's Avatar
Glad to see the set screws on the c hubs and front spindles are gone. Not so sure how the button heads for the king pin screws work since that's where the bearings were before.
frewster is offline
Old 07-27-2022 | 08:05 PM
  #3490
It looks like there is a pin on the top and bottom that drop through the c-hub and go into the spindle. The pis are held in place by the button head screw. Basically the same as the pins that hold the c-hub to the arm. It also appears that the bearings may be in the spindle instead of the c-hub now. Although I hope the bearings have been eliminated completely.
MX304 is offline
Old 07-27-2022 | 09:28 PM
  #3491
Matthew_Armeni's Avatar
No more bearings for the spindles/carriers. The spindles have recesses for steel sleeves that pivot around steel pins secured in the carrier like you described.
E1 Diablo, MX304 and frewster like this.
Matthew_Armeni is offline
Old 07-27-2022 | 09:38 PM
  #3492
Right on! Should be a lot more solid.
MX304 is offline
Old 07-28-2022 | 11:53 PM
  #3493
1evo RRR Driver's Avatar
What’s wrong wit this picture from REDRC?
1evo RRR Driver is offline
Old 07-29-2022 | 04:07 AM
  #3494
You don’t like the fuel line routing?! Lol!!
1evo RRR Driver likes this.
RandyJones is offline
Old 07-29-2022 | 04:09 AM
  #3495
And it doesn’t even have the new long spring spring on the rear shocks. Still the old short spring from the 2.0 car.
