Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-19-2021 | 05:24 PM
  #2686
Originally Posted by jamsandolina
Hello..what servo do you guys recommend for racing the TT02 in club racing??? I'm looking at two different Hobbystar lv servos. One is 109oz/.09 and the other is 139oz/.11 both of those numbers are at 4.8v because the Hobbywing wp 1060 ESC runs at 5v. I confirmed through Hobbywing USA. I have an off-road racing background. So my guess is with the smaller tires speed is more important than massive holding power. Thanks
Also be very careful of the Chinese knock off servos. They are NEVER close to rated speeds and torque.
Metalsoft is offline
Old 04-19-2021 | 06:35 PM
  #2687
What servos would you recommend??
jamsandolina is offline
Old 04-19-2021 | 10:04 PM
  #2688
fyrstormer's Avatar
I run Hitec servos in all my RCs. Fast, quiet, and not too power-hungry. I've never needed to replace one in 8 years.
fyrstormer is offline
Old 04-20-2021 | 09:22 AM
  #2689
Default Tble-04s ESC low voltage shutoff
Hello. I posted something about the new Tamiya Tble-04s ESC low voltage shutoff (6.2v) earlier and someone said that is too low. I've been doing some research and the Hobbywing 1060 brushed ESC has a two cutoff (6.5v) half throttle and (6.0v) full cutoff. Wouldn't the Tamiya ESC be ok to use since it's cutoff is basically in the middle of those two numbers. I'm afraid that if I get a Hobbywing 1060 it will start having the dreaded limp mode issue. The ESC is the last piece of the puzzle for my build. I'm running a Tamiya torque tuned motor. Thanks
Old 04-20-2021 | 10:57 AM
  #2690
zuqbu's Avatar
i am assuming that the previous comments have been in mind with a 2S LiPo battery. you don’t want to discharge a LiPo below 3.2 Volts per cell as you might risk to damage the battery. With good balancing between cells, 6.5 V is just enough to let you know to stop immediately while 6.2 is already risky. If you want to use the Tamiya TBLE I would recommend to use a LiPo alarm set to at least 3.3 V per cell.
zuqbu is offline
Old 04-20-2021 | 01:17 PM
  #2691
OK then that means the lipo cutoff for the Hobbywing 1060 ESC is too low then...right because it goes to half throttle at 6.5v and cutoff at 6.0v. Unless I'm understanding it wrong technically the car can still be driven until cutoff with the Hobbywing which is too low also. What ESC do the people use when racing in a Tamiya TCS novice class?? Do they use a lipo alarm also?? I'm alittle confused. Thanks
Old 04-20-2021 | 05:42 PM
  #2692
Backyard RC's Avatar
I was planning on running the stock steering assembly at first and then upgrading it after it likely fails but does it sometimes take out the chassis too. If so I can use the upgraded system from the start. I am curious about how well the stock set up works though.
Backyard RC is offline
Old 04-20-2021 | 05:49 PM
  #2693
All of Tamiya's esc's have a cutoff set for LIFE battery Which have a lower cutoff. I would leave it and just keep in mind of the cutoff. I have ran lipos on my TBL02S ( Which is the same esc pretty much with a different form factor.
Either keep in mind how long you are running, or get an alarm.
jamsandolina likes this.
Old 04-20-2021 | 07:41 PM
  #2694
Airwave's Avatar
Ordering the Tamiya screwdrivers was very very wise. Well played.
Airwave is offline
Old 04-20-2021 | 08:53 PM
  #2695
That's the first two items I purchased with my kit. Lol
Old 04-21-2021 | 05:20 AM
  #2696
Is it possible to use 64p gears with the Tamiya alloy motor mount? If so, what gearing combo would be appropriate for a Sport Tuned motor for general parking lot running/racings?
CTRJ is offline
Old 04-21-2021 | 07:59 AM
  #2697
Raman's Avatar
Yes
Raman is offline
Old 04-21-2021 | 10:58 AM
  #2698
Default Time to build!!!!
I'm about to start my build but have a question that I need answered. I plan on racing with this car on outdoor asphalt. What chassis would be better suited for that: the normal abs plastic tub or the hard plastic tub? The racing surface will basically be swept and blown off with a leaf blower. Which chassis tub will give me the best performance and why?? Thanks
Old 04-22-2021 | 12:11 AM
  #2699
Does anyone have the part number for the wheels that come with the TT02R version? I've looked everywhere with no luck. I found the tires but no luck locating the wheels. Thanks
Old 04-22-2021 | 12:20 AM
  #2700
Tamiya 19335728, see manual page 22, bottom half, under the prop shaft
JJ100179 is offline
