Unusual class (8.5t blinky)
Hi guys,
Coming back to the hobby after many years, discovered that at my local track people race touring cars with 8.5t motors without timing at the ESC (blinky). This is very unusual, right? I can't seem to find information about 8.5t blinky on-road...
I'd like some insights regarding battery choice. Should I go towards 'mod spec' batteries for better CG and wheight distribution or 'stock spec' would be a must as the 'punch' and capacity would be much needed in this case(?) . I don't have a clear understanding if a 8.5t motor at blinky mode would require a bigger battery than a 17.5t motor at blinky mode, for example (considering all the rest is equal - proper gearing, same weight, etc.). It's an asphalt track with mixed layout.
Thanks!
Thanks!
Thank you Dan!
And about capacity? I now that this can be tricky as there are many variables, but in general would a properly geared car with a 21.5t motor draw more or less energy than with a 13.5t motor? (more mAh drained from the battery after each run)
Thanks G!
Where I live we have very limited options for batteries to choose from. I narrowed down to these two based on availability and price:
1) Nosram - LiPo HV LCG 6700mAh Graphene-4 - 120C/60C: 999657 (274g)
2) Nosram - LiPo HV 7300mAh Graphene-3 - 130C/65C: 999552 (304g)
Mains are 6 minutes long here, and as I said before, class is TC 8.5t blinky. Based on that, what battery would you pick? Battery 2 is 10% cheaper. Appreciate your help guys.
Thanks Airwave. Guess I'll get the 7300. It's cheaper and we'll see how it goes capacity-wise. If it's too much I'll go down a bit in the future for better CG.
Unfortunately I don't have videos. Class was supposed to start this year, but due to the pandemics it was postponed to next year.
Where I live it rains a lot this time of year, so races are not scheduled to this period.
I'm in Brazil.
Our local track is a bit bigger, faster and bumpier, but also outdoor asphalt. I'll take a better look later.
I think people here chose to run blinky as a way of lowering costs while mantaining some sort of fairness. From reading about it, it looks like it doesn't work that way more often than not... lol
This choice reminds me to the old Dutch brushed modified class. Only 12 turns motors were alowed.
And basically nothing is wrong with the idea, it keeps the speed within a normal limit and blinky keeps away from a like 200 page manual and an exam to learn all settings of an ESC
It is probably the case, but with the level of the drivers here, 95% of them have enough power with 13.5 boosted. Sometimes we have to explain to the beginners that it is better to have a slower car which they can control than an uncontrolable rocket...
About the ESC setup it is just a habit in fact. Setup is pretty easy and we try to publish as setups as possible. Hobbywing is auto-mode is really nice by the way...
3Likes
