How does battery affects Low End Speed? >
Like Tree1Likes
  • 1 Post By Airwave
Old 10-07-2020 | 07:49 AM
AntreasRC's Avatar
Default How does battery affects Low End Speed?
Why does a 2S lipo (7.4v) has much more low end control of speed than a 3S (11.1v) on brushless system? I mean with 3S I cannot exit low speed corners smoothly because the motor is stuttering, though with 2S is so much better. I tried gearing up with 3S but the stuttering does not seem to be solved this way.
AntreasRC is offline
Old 10-07-2020 | 09:16 AM
dtr's Avatar
dtr
Do you run the same motor in both case? If yes, the cause might be that the the esc has to send more sparse pwm signal to the motor with the 3s for the same effective voltage. You can compensate for this by raising the throttle frequency.
dtr is offline
Old 10-07-2020 | 09:29 AM
DirkW's Avatar
Sensored or sensorless system?
DirkW is offline
Old 10-07-2020 | 01:13 PM
Lonestar's Avatar
was going to ask the same thing... sensorless I guess
Lonestar is offline
Old 10-07-2020 | 02:55 PM
Airwave's Avatar
That's not true. I've runned a Serpent 748e in 2S with a 4.5T and in 3S with a 8.5T and the low-speed control is the same. It depends from the quality of your combo (Hobbywing here)
Airwave is offline
Old 10-07-2020 | 08:15 PM
AntreasRC's Avatar
Sensorless. This problem arise for the low speed corners.
Old 10-07-2020 | 08:16 PM
AntreasRC's Avatar
I run the same motor. The question is about the battery voltage.
Old 10-08-2020 | 02:08 PM
Airwave's Avatar
The answer is in the lack of sensor... Sorry.
Jcharger13 likes this.
Airwave is offline
Old 10-08-2020 | 08:22 PM
the whole cogging effect has been worked on for a long time. the timing of the coil to the nuetral plane requires feedback(sensors). the more feedback the smoother it could be.
every time a coil pulls or pushes on a pole there is an acceleration and deceleration rate. the pole is attracted or repulsed from the coil and the current and rotor strength work against each other. cogging comes from this.
you can dampen these micro accelerations by adding weight to the rotor. you are adding to the inertia of the rotor. you can also gear the car so that the gear train dampens these micro accelerations. a 3:1 gear ratio will dampen the motor more than a 4:1.
Bry195 is offline
Old 10-09-2020 | 02:06 PM
AntreasRC's Avatar
Thanks. I make lot of effort for a detail acceleration because I run 1/10 touring car. What rc car type you are talking about? Maybe is time to get a sensored system
Old 10-09-2020 | 02:08 PM
AntreasRC's Avatar
Originally Posted by Bry195
the whole cogging effect has been worked on for a long time. the timing of the coil to the ultra plane requires feedback. the more feedback the smoother it could be.
Thank you that was really informative. So that coil effect depends on the input voltage. That makes sense
Old 10-09-2020 | 07:52 PM
yes in that voltage and current make power. a lower turn motor has more power so its a fair assumption to say it has more torque at whatever speed it is that you notice the problem.
Bry195 is offline
Old 10-10-2020 | 08:54 AM
AntreasRC's Avatar
The motor is 3000kV 9T from Dragon-RC. Not much of torque but still the problem exist when steering. I also noticed the lower speed I can get with 3S is higher than with 2s.
