Detonated headbutton and top of piston >
Like Tree1Likes
  • 1 Post By Cant drive
Old 09-16-2020 | 10:17 PM
Cant drive's Avatar
Default Detonated headbutton and top of piston
Is there any risk of running a detonated headbutton and piston? Or is it worth getting a new headbutton. This motor was running great until I ran it out of fuel and the glowplug went. I decided to rebiuld it and noticed the headbutton and top of cylinder are insanely detonated up.
Cant drive is offline
Old 09-16-2020 | 11:20 PM
dan_vector's Avatar
If the piston skirt and liner are not scratched or damaged then you can get away with it. You will loose some performance but the engine will run so long as the piston skirt and liner is not damaged. I've run plenty of engines like that over the years mainly in as practice or wet engines though not my primary race engines.
dan_vector is offline
Old 09-17-2020 | 01:48 AM
When you have an old glowplug, you can clamp the tip in a Dremel/drill/lathe and screw the button on. With the use of 1200 grit sandpaper spinning the button arround you can make the button as new again.
With the same sandpaper you can also make the piston smooth again.
Roelof is offline
Old 09-17-2020 | 01:54 AM
dan_vector's Avatar
An option, don't forget to check head clearance with tin-solder afterwards.
Old 09-17-2020 | 05:48 AM
Cant drive's Avatar
Nothing else is damaged in the motor, you cannot tell anything is wrong by looking at the side of the piston or the sleeve/rod/crank/bearings The sandpaper option is intriguing since I don’t need to purchase anything and I think I’ll be doing that when I have the time to
dan_vector likes this.
