Help with dead lipos >
Like Tree1Likes
  • 1 Post By billdelong
Old 08-29-2020 | 07:16 PM
Shnoo's Avatar
Default Help with dead lipos
Hey!
Ive got 3 4s batteries and 2 3s batteries that have a dead cell.
(This wasn’t my doing, bought a big battery lot)
Im not real technical when it comes to batteries, I know how to take care of them and how to use them, but not much more.
Is anyone able to remove the dead cells and turn them into 3 3s batteries and 2 2s batteries for a charge?
Or if not, does anyone have any guidance on how to do it without blowing myself up?
Thanks,
Shnoo
Shnoo is offline
Old 08-30-2020 | 09:14 AM
Yes, you can re-wire the packs to remove the dead cells, but you can't combine cells between different aged packs because the cells won't be matched.
What is the IR of the good cells? If any cell is above 7mΩ then I wouldn't waste the time.
If you don't know what you're doing, then simply discard the packs, otherwise do this at your own risk!
Andy Koback likes this.
billdelong is offline
Old 08-30-2020 | 09:31 AM
the rc guy's Avatar
1st off youll never blow yourself up with a lipo.. they dont blowup total myth
they will hiss for a few second then vent the white smoke then burn off the inside material..seen nicads blow up when dropped to a cement walk seen nimh blow under same event.
you can remove dead cell and convert the others to how ever many live cells are left. but like said not a good idea to mix cells from different packs
when a lipo is going to vent
Hissssss
vent-smoke
Fire
never blows up
the rc guy is offline
Old 08-30-2020 | 12:38 PM
Geezatec's Avatar
What's IR or voltage of each cell? Dont know what you mean Dead Cell.
Geezatec is offline
