Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 06-20-2020 | 01:37 PM
  #9931
simple's Avatar
Originally Posted by NutDriver
new Bitty body will likely resemble this closely.
Nice, but hardly a "gamechanger" in a class where the body "doesn't really matter"
Billy Kelly likes this.
simple is offline
Old 06-20-2020 | 08:28 PM
  #9932
STLNLST's Avatar
you running the same USGT class that we currently run? Body does matter.
Scott B and godzukihop like this.
STLNLST is offline
Old 06-20-2020 | 08:56 PM
  #9933
Billy Kelly's Avatar
Tech Prophet
That was the appeal of the class. A wide range of bodies. For the majority, body isn’t going to make the difference. Fast guys could use a shoebox, they’d still be the fast guys. Now it looks more like euroGT then USGT.
Raman and egalsim like this.
Billy Kelly is online now
Old 06-20-2020 | 09:21 PM
  #9934
STLNLST's Avatar
yes partially. Some of these bodies just look cool and aren’t the bodies I’d try ro race with. Mark R. himself couldnt beat me running some of the bodeies currently on the market
STLNLST is offline
Old 06-20-2020 | 09:37 PM
  #9935
I miss the original intent of scale this class was "supposed" to have too.
Our club runs a spec GT class and all the bodies have to be real scale cars. Super tight racing and the cars look great. Only scale GT sports cars and scale rally cars. Zero body advantage so I rock what I like.
Raman, DARKSIDE, egalsim and 1 others like this.
dman18t is offline
Old 06-20-2020 | 10:12 PM
  #9936
Tech Prophet
yes partially. Dome of these bodies just look cool and aren’t the bodiesi’d try ro race with. Matk R. Homeself couldnt beat me ruuning some of the bodeies currently on the market
I’m running a badly beaten Camaro body. Left is today practice on carpet. Right is a practice race heat on pavement. I’m still off the pace of the fast guys. How much would a newer body improve me. With actual racing starting back next weekend. I might have to find out. Considering this car hadn’t been run in two years. I’m very suprised by these numbers
Old 06-21-2020 | 05:39 AM
  #9937
Tech Prophet
Old 06-21-2020 | 02:33 PM
  #9938
STLNLST's Avatar
Depends on your setup. For me personally the Camaro is a concourse only body. I would bever tun it as a race option.
STLNLST is offline
Old 06-21-2020 | 04:02 PM
  #9939
egalsim's Avatar
is that a tamiya body?
egalsim is offline
Old 06-22-2020 | 12:15 PM
  #9940
Tech Prophet
I’ve run a TC body, The stratus, Caddy, Camaro even a VTA Mustang body on my USGT car. Times were all around the same. I’m not at, or ever probably will be, at the level where body makes much difference
glennhl likes this.
Old 06-22-2020 | 12:25 PM
  #9941
MD brought up this body: https://aplastics-rc.com/delorean-dm...IbWTYxOa4lrXMs
.... Now... is it cheating to have the MrFusion on it? What's the word on flux capacitors?
Raman and Billy Kelly like this.
Nerobro is offline
Old 06-22-2020 | 07:03 PM
  #9942
You are OK if the flux capacitors are set to blinky mode!
glennhl is offline
Old 06-22-2020 | 08:04 PM
  #9943
I was right there with you a month ago. I read and watched allot of stuff on f1 setup and so on. low speed is primarily a mechanical adjustment in the car to get grip. High speed is primarily adjusting the aerodynamics to get grip. And in between you probably know. I struggled for weeks on a rear grip issue in high speed corners. A friend (marcos) told e to get a neutral body. I did and it worked. I cant say i completely understand aero yet but a body switch stopped my car from losing the rear. Not trying to argue. I was right with you a couple weeks ago. Maybe a body will make me fast but i am happy it gave me the grip I needed.
Bry195 is offline
Old 06-22-2020 | 08:12 PM
  #9944
Raman's Avatar
Yes. I run that in our VTA club races. 👍
Raman is offline
Old 06-22-2020 | 08:37 PM
  #9945
Tech Prophet
I don’t think I’d call where I’ve run at high speed. The carpet track is too small. I’m not sure how big the parking lot tracks will be this weekend. I’ll have to bring my measuring roller. . I seen videos from a Florida track. Looks nothing like what we have. Once did, but it closed before I got there.
I’ve got a few bodies that I bought with the plans to compare. Unfortunately on road was in bad place most of last year. Both an outdoor and indoor track closed. Things are just now starting back up. While I can practice on the carpet track. It looks like most racing will be outside for the summer
Bry195 likes this.
