Futaba PCM
Old 10-21-2019 | 10:13 PM
Default Futaba PCM
Hello everybody; I have one question about a vintage FUTABA RC SYSTEM. It says PCM but I really do not know if it does use crystals. I see a crystal in the receiver but can not find a crystal in the transmitter. How does it work?
alexhahner is offline
Old 10-21-2019 | 11:32 PM
sosidge's Avatar
What is the model? PCM radios would normally have a crystal, Futaba did do a radio with a synthesized transmitter module (3GR) but I don't think that was PCM.
sosidge is online now
Old 10-21-2019 | 11:55 PM
corallyman's Avatar
Almost certainly there will be a crystal for the transmitter. Most likely the radio has a module unit that will house the crystal within it. There should be tabs on two sides of the module to remove it and get to the crystal. Like the previous poster said more info or picture will help.
corallyman is offline
Old 10-23-2019 | 11:04 AM
TurnNBurn's Avatar
I still have my old Futaba 3PJS Radio, which uses FM crystals. You have to be specific, because I believe that the radios that came before PCM was introduced used AM crystals. I know for a fact that I couldn’t use my old Magnum Jr. crystals because of it.
Chances are, if it’s a pre- 2.4GHz radio, it uses crystals.
TurnNBurn is offline
Old 10-23-2019 | 11:12 AM
If it is 3PJ PCM, there is a module in the back of the radio that you can pull out. The receiver will be on the bottom of it. There is a groove where the module meets the radio were you can also see where the crystal goes. You do not have to remove the module to remove the crystal.
AxiomJacob is offline
Old 10-23-2019 | 12:19 PM
As mentioned, it is in the TX module
PCM is a digital version of PPM. The pulse width of each channel is converted into an 10 bit number and that number is as a serial bitstream transmitted to the receiver which translates the serial bit stream into sepperate PWM signals
Roelof is online now
Old 10-23-2019 | 05:39 PM
pcm stands for pulse code modulation...a line of computer code is sent out with the fm signal
thefnshow is offline
