Like Tree195Likes
Novarossi engines thread
Old 06-05-2019 | 01:55 PM
  #5821
Default Does anyone have any insight on the .21R-PTAN limited edition?
Just picked one up but have no idea about it. is it based off a Flash or Ison? Any recommendations on exhaust?
Thanks guys
NitroPhene is offline
Old 06-09-2019 | 06:57 AM
  #5822
TeamCarnage's Avatar
What's up with the offset carb? I stripped a head screw out and wanted to use another Mito crankcase, but no dice. Anyone make a small heli-coil?
TeamCarnage is offline
Old 06-09-2019 | 07:02 AM
  #5823
Tap the M3 hole to M3.5 and use a M3.5 bolt
Roelof is offline
Old 06-09-2019 | 08:11 AM
  #5824
I did think about that! Thanks for the vote of confidence!!
Old 06-09-2019 | 08:47 AM
  #5825
Probably you need to drill up the head as well due a bigger head (or grind down the head of the 3.5mm screw)
Regarging the offset carb, no way to put that crank into a crank case with a center carb. The crank timing will be too far off because the crank timing is made by the crank shaft in combination with the crank case.
Roelof is offline
Old 06-10-2019 | 06:18 AM
  #5826
Thumbs up
That was how I found out about the offset carb not being compatible with the centered carb. It started and ran,,, but backwards!! lol. Drilled and tapped all the holes and all is well. Thanks for the help!
Old 06-16-2019 | 10:27 AM
  #5827
Does xceed ins box fit novarossi memphisto 12 engine?
B.S. is offline
Old 06-17-2019 | 01:05 AM
  #5828
dan_vector's Avatar
Yes it does. The 1/10 novarossi one is better as it has an offset air filter boot to give a bit more clearance from the head.
dan_vector is offline
Old 07-07-2019 | 12:20 PM
  #5829
savage24x's Avatar
Hey guys, what glow plugs should I use for a Flash .12? Picking it up in a Natrix 748wc I got for cheap. Outdoor asphalt... 70-90F right now... 16% fuel.
http://www.novarossi.it/2012/index.p...lash-12pt.html
savage24x is offline
Old 07-07-2019 | 01:22 PM
  #5830
That what is advised in the manual and webpage, that will be around a 6
Flash.12-3 Tuned - NOVAROSSI WORLD
They even say a 5
Roelof is offline
Old 07-21-2019 | 04:26 PM
  #5831
LOW ET's Avatar
any thoughts on the differences between the mito .12 and the mephisto .12? i see the mito has the aluminum carb and the mephisto has the plastic carb, thoughts on this? to people who have ran both, which do you like better, which is faster?
LOW ET is offline
Old 08-08-2019 | 06:50 AM
  #5832
eevul's Avatar
Is anyone encountering problems with their carbs coming lose to the point of falling off on their Mitos? I've had 2 brand new .12 Mitos that no matter how tight I have the carb, it still comes out. I've tightened the screw so much at one point that I snapped the head off of it. I'm also not the only one at my track having the same problem. There are about 6 to 10 people that have had the same issue in the last year. We have a very healthy nitro touring class and this carb issue is affecting a lot of the racers who are running NovaRossi Mito .12. The track is fairly smooth and I tend to run fairly clean so no hard crashes (if any) would be the cause. Anyone else having the same problem?
eevul is offline
Old 08-16-2019 | 10:32 PM
  #5833
TurnNBurn's Avatar
I too would love to get a consensus on this, as I just picked up a Serpent 750 after an almost 20 year hiatus from racing, and would love to run a Novarossi again like the good old days. Is it best to run the “latest and greatest”, or is the Mito WC (Ceramic) still good enough to hold its own?
TurnNBurn is offline
Old 08-17-2019 | 04:46 AM
  #5834
LOW ET's Avatar
what will be the performance characteristics between the 41016 and 41014 manifolds?
LOW ET is offline
Old 08-20-2019 | 08:16 AM
  #5835
TurnNBurn's Avatar
Hmm, hard to believe that there’s really no info on the 14 (nor is it on the “recommended” list for any of their current on road engines), but based on the numbers and because it is a “straighter” pipe compared to the curvier looking 41015-17 models, I’d venture to say that it’s the shortest of the 4, and thus, would highly favor top end over acceleration compared to the 16 - especially considering that the 16 is the happy balance between the 15 and 17.
