Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 04-23-2019 | 10:55 AM
  #8866
Originally Posted by Panther6834
BEST paint job on the AGATA that I've seen (so far)...I'm jealous. I do have to ask, where did you get the 'Lamborghini' stickers/decals (on rear wing, as well as to the left/right of the engine), and the Lambo bull sticker/decal. Also are they stickers attached to the outside of the body (after painting), or are they decals attached to the body from the inside (before painting)? Lastly, if you could PM the info, I'd greatly appreciate it.
meow that's hot.
Azsmartbet is offline
Old 04-23-2019 | 05:11 PM
  #8867
team green's Avatar
Originally Posted by Josh-n-ya
Brahahahaha!!! 😂
You know you like my Prius I mean Agata.😜
massenb203 likes this.
team green is offline
Old 04-23-2019 | 05:37 PM
  #8868
Billy Kelly's Avatar
Tech Prophet
The actual SuperGT Prius
team green and massenb203 like this.
Billy Kelly is offline
Old 04-24-2019 | 07:30 PM
  #8869
Originally Posted by team green
A buddy of mine ( Josh-n-ya) told me my Agata looks like a stretched out Prius. Now that’s all I see.😡😡😡
He needs glasses...looks like a Lambo to me.
gigaplex likes this.
Panther6834 is offline
Old 04-24-2019 | 07:32 PM
  #8870
Now...I'M BLIND !!!
Old 04-29-2019 | 07:18 PM
  #8871
Originally Posted by bertrandsv87
Of course.....Check these numbers out...Any other 21.5t numbers out there????
Ok, finally received my 21.5T. Here ya go:
Old 04-29-2019 | 10:49 PM
  #8872
Opinions
For ESC in USGT are you using a higher amp esc? I'm using a r1 80amp considering 160a or Michmore.
Old 04-29-2019 | 11:03 PM
  #8873
Originally Posted by Azsmartbet
Opinions
80 amp is just fine for 21.5. You will not see a speed advantage when moving to a 160.
trigger is offline
Old 04-30-2019 | 08:42 AM
  #8874
so funny a well respected driver at my track says you will and I agree with you. I just don't see a 21.5 drawing that much
Old 04-30-2019 | 08:56 AM
  #8875
On resistance matters. On resistance and maximum current capacity are only tangentially related. There was a time... where r/c car action actually tested that sort of thing.
Nerobro is offline
Old 04-30-2019 | 09:01 AM
  #8876
beemerfan's Avatar
I mounted an amp meter in a VTA car once to evaluate the need for higher "C" rating on batteries. I did dead stop burn outs on the street and also had it in the car for practice laps. Result was about 12 amp average draw on the track and about 22 amp draw peak for hard acceleration from a dead stop. I don't remember my gearing at the time but it was probably between 3.3 and 3.8 FDR. Figure about 15% more draw for a 21.5 and you would be under 14 amps average on the track and just over 25 amps peak. So no need for a higher rated speed control based on amperage.
HOWEVER, higher rated speed controls tend to have lower internal resistance and less voltage drop. So basing your decision on a lower voltage drop rather than the amperage rating makes more sense. I doubt there is any sort of industry standard for the numbers manufacturers publish about their products. You can use them as guidelines but you would have to setup some sort of controlled experiment to actually compare different speed controls.
beemerfan is offline
Old 04-30-2019 | 09:06 AM
  #8877
I wonder if the lower heat alone is worth it
Old 04-30-2019 | 10:06 AM
  #8878
How much heat do you think there will be? Most of the heat in ESCs I've played with comes from the hilariously crappy BEC vreg. Most of the ESC's I've been in, use a linear vreg. And if we're lucky, it's LDO. Linear regs are tiny little heaters...
Nerobro is offline
Old 04-30-2019 | 10:38 AM
  #8879
OVA's Avatar
OVA
Bingo
OVA is offline
Old 04-30-2019 | 08:17 PM
  #8880
I think most higher Amperage ESCs also have higher brake capacity.
Bry195 is offline
