Mini-96 World Challenge
#3646
Class- Stock AAA
Date- 6/1/2026
Location- Lake Forest, CA
Race Time- 4:56:57 / 296.57
Fastest Lap- 3.63
Chassis- PN2.5 MR03 RWD
Body- Jomu- missing back windows
Wheelbase- 98mm
Tires- Reflex40 / RR Marka 10
Wheels- Nexx disc 20mm +1/ AMA Racing Interlocks+3
Motor- PN 3500 kV
Batteries- PN 900
Front Springs- PN Blue
T-Plate- PN Carbon #4
Motor Mount- Nexx LCG
Dampener (If applicable)- Nexx damper and dual spring shock (Kyosho Red 5k grease)
Dampener Fluid (If applicable)- Kyosho yellow 10k grease
Gearing- Spur 44T Pinion 14t
Date- 6/1/2026
Fastest Lap- 3.63
Wheelbase- 98mm
Motor- PN 3500 kV
Batteries- PN 900
#3647
Class- Open Mod
Date- 6/1//2026
Race Time- 4:39:89 / 279.89
Fastest Lap- 3.35
Chassis- Team Associated RC28R/ Nexx upgrades Top deck and front DAA
Body- Jomu
Wheelbase- 98mm
Tires- FR Reflex 35 / RR Marka 5 slicks
Wheels- Nexx / disc 20mm +1/ AMA Racing Interlock +3
Motor- Reedy 3500 kV
Batteries- Reedy 400 mah
Front Springs- Nexx DAA -Yellow
Motor Mount- Stock- Middle Roll Center
Dampener (If applicable)- 15k grease
Dampener Fluid (If applicable)- Top Shock 30k grease, Front Shocks 15k grease
Date- 6/1//2026
Fastest Lap- 3.35
Body- Jomu
Wheelbase- 98mm
#3648
Ok Yall, I FINNALY figured out the issue with my laptop! It updated on its on the other day, and it put itself into airplane mode, and a few others changed too????? Anyway crises averted, as I thought I was going to have to wipe and reinstall the hard drive!
So, I'll get on adding my times and tallying the results! SORRY about the delay! Me and Software mix like oil and water!
Yall Have Fun, Drive Fast, and keep it Shiny side UP!
#3649
May 2026 BoxStock
Date- 05/23/2026
Location- Central Texas
Race Time- 5:47.900 / 347.900
Fastest Lap- 4.420
Chassis- MR04
Body- McLaren GTR
Wheelbase- 98mm
Wheels- F- 20mm N +2mm PN BBS Yellow R- 20mm W 0mm PN BBS Yellow
Tires- F- PN KS1038 WORN R- Marka V1R10
Motor- Kyo White End Bell
Batteries- Gens Ace 750HV
Front Springs- PN Green
T-Plate- PN #4 Carbon Fiber
Motor Mount- Kyosho 04MM
Dampener (If applicable)- Kyosho Top Spring Shock- green spring
Dampener Fluid (If applicable)- 15k Grease on top shock
Gearing-7/44
Notes-It's still going even with the crappy steering. It McLaren GTR is a runner after you get the chassis dialed in!
Date- 05/23/2026
Fastest Lap- 4.420
Chassis- MR04
Body- McLaren GTR
Wheelbase- 98mm
Gearing-7/44
#3650
May 2026 Stock
Date- 05/24/2026
Location-Central Texas
Race Time- 5:40.437 / 340.437
Fastest Lap- 4.182
Chassis- PN 2.5W/MR03EVO board/ 04 arms
Body- Kyo R8 2010 Bilstein
Wheelbase-98mm
Tires-F-PN KS1138 / R- Marka V1R10
Wheels- F-PN N+2mm 20mm PN BBS / R- PN W+3mm 20mm Kyo BBS black
Motor-PN 3500Kv
Batteries- GensAce 750HV
Front Springs-PN purple
T-Plate-PN #3 Silver Carbon Fiber
Motor Mount-PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Green top/bottom springs) PN Dual Spring Top Shock (Green Front/Purple Rear)
Gearing-13/53 PN Ball Diff
Notes- Just trying out the body for the first time and it is nice but a little top heavy, causing TR. More testing will need to be done between it and the 2015 R8!
Date- 05/24/2026
Fastest Lap- 4.182
Wheelbase-98mm
Motor-PN 3500Kv
#3651
May 2026 ProStock
Date- 05/31/2026
Race Time- 5:34.765 / 334.765
Fastest Lap- 4.174
Chassis- PN 2.5W/MR04EVO board/ 04 arms
Body- McLaren 12C- Lexan windows no wing
Wheelbase- 98mm
Tires-F- PN KSK 540 / R- PN KSK 2030
Wheels- F- 3D Disk Wheels +2mm 19mm Blk #8 dsk / R- 3D Disk wheels +2mm 20mm Blk
Motor-PN 5500Kv Anima Sensored
Front Springs- Kyo Orange
T-Plate-PN #4 White Fiber Glass
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS ( Green top/ Green bottom spring) PN Dual Spring Top Shock (Silver Stock Springs)
Gearing-10/52 PN Ball Diff
Notes- Car was VERY good!
Date- 05/31/2026
Fastest Lap- 4.174
Wheelbase- 98mm
#3652
May 2026 Narrow
Date- 05/31/2026
Race Time- 6:00.771 / 360.771
Fastest Lap- 4.413
Chassis-MR03EVO
Body-Yaris
Wheelbase-90mm
Tires- F-PN KS Medium LH (KS1138) / R- PN KS Soft LH (KS1134)
Wheels-F- 3D Disk N-0mm 19mm Black #4 dsk / Bronze -1mm
Motor-PN 3500Kv
Front Springs-Kyo Orange (soft and short) on Inner Tube Shock Set dry
Motor Mount-Nexx 90/94mm MM
Dampener (If applicable)- PN DDS Purple top and Bottom springs
Gearing- 13/53 PN Ball Diff
Notes- Car is quick, but TR was an issue and I ran out of time to tweek on the Yaris! I'm really going to test it this month since I got a 86mm 934Porsche to run it against.
Date- 05/31/2026
Fastest Lap- 4.413
Chassis-MR03EVO
Body-Yaris
Wheelbase-90mm
Motor-PN 3500Kv
#3653
May 2026 Porsche
Date- 05/31/2026
Race Time- 5:53.358 / 353.358
Fastest Lap- 4.391
Chassis- MR04EVO
Body- Porsche 911 GT3 RS (MZN232)
Wheelbase- 90mm
Tires-F- PN KSK540 almost worn out / R-Marka V1R10 half worn but good grip still
Wheels- F-PN N +1mm 19mm Black 3D Disk #1 dsk / R- W 0mm 20mm Black 3D no dsk
Motor-PN Anima V4 3500Kv Sensored
T-Plate-PN #4 Spring Steel
Motor Mount-Nexx 90/94mm RM
Dampener (If applicable)- PN DDS (Purple top disk/Green bottom spring)
Gearing-11/53 PN Ball Diff
Notes- Only a single run! Ran out of time! Chassis has now been switched to a Kyo RM Pod so I can run the 934! We'll see how it goes, as the Kyo 4100kv SUX!! It has NO POWER!
Date- 05/31/2026
Fastest Lap- 4.391
Chassis- MR04EVO
Wheelbase- 90mm
#3654
May 2026 MX-5 Open
Date- 05/31/2026
Race Time- 5:36.399 / 336.399
Fastest Lap- 4.131
Chassis- PN 2.5W / MR03 board
Body- Kyosho MX-5
Wheelbase- 90mm
Tires-F- PN KS Medium LH (KS1138) / R- Old Marka V1R10
Wheels- F-PN N +1mm 19mm Black 3D Disk wheels no disk / R-W DXR Black carbon -1mm 20mm
Motor-Rocket 3500Kv
Front Springs- PN White
T-Plate-Nexx #4 Carbon Fiber
Gearing-13/54 PN Ball Diff
Notes- Only ran a few times, and this was pretty damn good! Especially at 90mm!
Date- 05/31/2026
Fastest Lap- 4.131
Body- Kyosho MX-5
Wheelbase- 90mm
Motor-Rocket 3500Kv
#3655
May 2026 Open
Date- 05/19/2026
Race Time- 5:16.780 / 316.780
Fastest Lap- 3.977
Chassis- MRX ME
Body- Mako X2
Wheelbase- 98mm
Tires-F- PN KS1138 / R- Marka MZR-V1R10
Wheels- F- 19mm N -1mm 3D no Disks / R- 21mm W +3mm A. Ma 3d wheels
Motor- GL 3500kv
Batteries- Reflex HC 340mAh
Front Springs- White
T-Plate-N/A
Motor Mount-
Dampener (If applicable)- Brown side- Yellow rear
Dampener Fluid (If applicable)- 15K Atomic Grease on ALL dampers
Gearing- 10/53 PN Gear Diff
Notes- Went to the Mako X2 lexan body, as it just felt better on this layout. Alvin Ma's 21mm wheels allow me to use old thin Markas!
Date- 05/19/2026
Fastest Lap- 3.977
Chassis- MRX ME
Body- Mako X2
Wheelbase- 98mm
Motor- GL 3500kv
T-Plate-N/A
Motor Mount-
#3656
MAY 2026 RESULTS
Hey Yall, Sorry for the delay in the EOM results and tallying, CPU problems are sorted, HOPEFULLY, and I got my runs added and figured! I have to help my wife get ready to take one of the dogs into work, she's a vet tech. So I will come back and finish the results, but I thought someone might be waiting!
WELCOME to the New drivers, and THANKYOU ALL who continue to run with us!
AlexOmarSoto-Pagen had the SMOKIN FAST 75 Lap run at 266.222, and joelisenat and the Blistering fast lap of 3.299!!!!!
MAY 2026 RESULTS
BOX STOCK
1) joelisenat*********** 316.897 / 3.950
2) ekim628************** 319.160 / 3.970
3) Traveler2************ 320.695 / 4.088
4) GerryBurr************ 329.460 / 3.931
5) zoomtime************* 336.148 / 4.235
5) AM03GT*************** 340.856 / 4.360
6) BoxxerBoyDrew******** 347.900 / 4.420
7) Smokey84************* 351.035 / 4.319
8 ) GregCheng*********** 358.937 / 4.417
9) georg.fs************* 374.484 / 4.766
10) MikeReidy*********** 393.962 / 4.526
11) ckj***************** 418.927 / 4.990
12) MathewBull********** 443.428 / 5.020
13) GabeMartin********** 464.560 / 5.050
14) IB Hester*********** 755.797 / 7.868
STOCK
1) joelisenat*********** 293.097 / 3.719
2) ekim628************** 296.570 / 3.630
3) Traveler2************ 304.247 / 3.853
4) AM03GT*************** 339.541 / 4.331
5) BoxxerBoyDrew******** 340.437 / 4.182
6) Smokey84************* 345.090 / 4.225
PRO STOCK
1) joelisenat*********** 300.887 / 3.761
2) BoxxerBOyDrew******** 334.765 / 4.174
3) MathewBull*********** 461.641 / 4.869
STOCK 86
1) Smokey84************* 379.729 / 4.733
2) MathewBull*********** 451.184 / 5.184
NARROW
1) Traveler2************ 354.470 / 4.495
2) BoxxerBOyDrew******** 360.771 / 4.413
3) MathewBull*********** 468.057 / 5.193
PORSCHE
1) BoxxerBoyDrew******** 353.358 / 4.391
2) Smokey84************* 387.128 / 4.768
3) MathewBull*********** 409.119 / 4.847
OPEN MX-5
1) BoxxerBoyDrew******** 336.399 / 4.131
2) Traveler2************ 354.470 / 4.495
OPEN 2WD
1) AlexOmarSoto-Pagen*** 266.222 / 3.333
2) joelisenat*********** 268.614 / 3.299
3) ekim628************** 279.890 / 3.350
4) JarenStevens********* 299.540 / 3.515
5) CuriousDolphin******* 300.040 / 3.760
6) BoxxerBoyDrew******** 316.780 / 3.977
5) AM03GT*************** 335.674 / 4.257
I think I got everyones times correct, but if I screwed up PM me and Ill get it fixed asap!
THANKS AGAIN AND TAKE CARE!!!
Andy (BoxxerBoyDrew) Curington
UPDATE:
UPDATE I got everyones times in from Facebook now! SORRY, in a hurry and just spaced and forgot to look! My mind is GONE!
I added all I could find, even those without the Time form filled out. Stuff happens, and I know we all sometimes forget to come back and make an official post, but it makes it soo much easier if the form (Class, Date, Time, etc...). Also if your putting all your times on one page, please put the classes in BOLD TYPE. Again it's MUCH easier to find with my old arse eyes! LOL Again, THANKYOU ALL for running with us!!!!
MAY 2026 RESULTS
BOX STOCK
STOCK
PRO STOCK
STOCK 86
NARROW
PORSCHE
OPEN MX-5
OPEN 2WD
UPDATE:
#3657
As for upgrades, Boca Bearings are the only one worth doing. If I really pushed it I could probably hit the high 4s. The car keeps picking up speed as the motor breaks in too. That pass was only my second time taking it out straight from the box.
3035Likes
