Tekno RC ET410 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree469Likes
Last edit by:
Print Wikipost
Old 01-25-2019 | 07:48 PM
  #766
Originally Posted by smkd13
hit a wall and a barrier tube. Today I broke a shock post lol 🤦🏻*♂️ I cannot won lol
Bummer man. Sounds like this new layout can be brutal....
Teknewbee is offline
Old 01-25-2019 | 07:50 PM
  #767
Originally Posted by killer rock
I'm interested to know how many of you are 2 pole vs 4 pole in this truck?
I'm running a 2 pole. Speedzone Peerless V2 5.0
Old 01-25-2019 | 08:02 PM
  #768
smkd13's Avatar
i am running a 6.5T Trinity Monster and it seems plenty powerful
smkd13 is offline
Old 01-25-2019 | 08:04 PM
  #769
smkd13's Avatar
no not really. The arm against the wall was my fault. Kinda hit it hard lol. The shock mount was because clipped the pipe on the sweeper and tumbled into the wall. That was all that broke though bulkhead and tower seems to be fine
smkd13 is offline
Old 01-26-2019 | 10:04 AM
  #770
4 pole. Tekin pro2 5100kv, 17t pinion, runs cool, gobs of power.
m59y is offline
Old 01-26-2019 | 10:40 AM
  #771
RCSteveH's Avatar
wow, must be flying thru the roof. I’m running 4300kv with 16t and I get my best laptimes.
motor never gets over 125 without a fan.
stays around 110 with fan
RCSteveH is offline
Old 01-27-2019 | 11:20 AM
  #772
rustyus's Avatar
Getting ready for potential stock ball cup failure, and hunting for replacements. I see people were using Team Associated's 91453 HD ball cups in their EB/ET410s. Those Associated ball cups are now discontinued, and can not be found unless you want to pay an absurd amount of cash for them .
Is Associated's 91722 B6/T6 ball cups now the replacement of choice for the Tekno truggy?
Or, was there a running change in Tekno's ball cups?
rustyus is offline
Old 01-27-2019 | 11:25 AM
  #773
wrightcs77's Avatar
B6 ball cups or yokomo HD ball cups.
I run sc10 4x4 ball cups with the lunsford super duty tie rods (3.5mm tie rods vs 3mm stick size). No drilling required for the sc10 4x4 rod ends, they are made for 3.5mm tie rods.
wrightcs77 is offline
Old 01-27-2019 | 03:01 PM
  #774
Default Et410
I'm running a 5100kv 4 pole with 16tooth for track and 18tooth for bash! With turbo added, thing hauls
Redtail2426 is offline
Old 01-27-2019 | 03:36 PM
  #775
RCSteveH's Avatar
theres nothing like 30° of turbo timing at the end of the straight 😎
RCSteveH is offline
Old 01-28-2019 | 02:23 PM
  #776
sea1swk's Avatar
Took my eb410/MIP and made a et410/MIP. Maclan 6.5, thing is a blast to drive. Only issue is that I broke 2 rear bulkheads with 3 batteries. Need to get a rear tower support in it, I assume.
eb410/MIP to et410/MIP
FastPete and Teknewbee like this.
sea1swk is offline
Old 01-28-2019 | 03:54 PM
  #777
smkd13's Avatar
M
i haven’t had the pleasure of breaking a bulkhead yet but I have torched 4 hinge pins, 3 arms, 1 rod end, and 1 hinge pin pill and that is after 6 days of running it.
Cool ok thing I am hitting mid 16s and getting close to hitting 15s on our track that is a 16-17 second track
Teknewbee likes this.
smkd13 is offline
Old 02-04-2019 | 11:58 AM
  #778
sea1swk's Avatar
So I built my eb410/MIP into a et410/MIP. Day 2 at the track, had added the stock rear Bulkhead supports, onto the MIP Chassis. Made it 1/2 way around the track, and destroyed the stock 81 tooth spur gear. I'll upgrade from the the 48 pitch to 32 pitch Spur/pinion? I then watched 2 other et410's on the track. They flew like arrows over the jumps. My MIP chassis setup, on gas, spun backwards in the air. Hit the breaks, spin forwards in the air. Great fun, but not fast. I'm going switch to the stock Chassis, so a standard et410. As I am a slacker, I like to look at a setup sheet from a Pro, than tweak / adjust to my driving. Am I blind, or is the only setup sheet out there, carpet? No high bite clay or even dirt?
sea1swk is offline
Old 02-04-2019 | 12:43 PM
  #779
smkd13's Avatar
that is weird cause I don’t have that problem with mine. I have yet to find one. I need to put mine together. I am running on high bite clay and my setup work pretty good for me. Idk. Mostly I just moved the rear shock out on the shock tower then put orange springs on the rear. Also running about 25mm ride height. Last thing is up put AE 37.5wt (463.5cst) in the rear shocks. Running a 16t pinion on the 32p spur. It rips. Pretty much it is stock except for those changes
smkd13 is offline
Old 02-04-2019 | 01:13 PM
  #780
sea1swk's Avatar
Our track has some pretty serious steep jumps. Originally I thought the eb410, was to slow in the corners for our indoor clay track. I pre-ordered the MIP Chassis. Before I received the MIP chassis, tried moving the rear shocks in front of the rear tires. That helped a lot. I then put the MIP chassis on, because I already ordered it. I like the eb410/MIP. But if I had it to do over, I would not have done the MIP. Moving the rear shocks was enough, in my opinion. Now I am playing with the et410, already with the rear shocks in front of the rear towers, I am not sold the MIP is the way to go. Maybe carpet? But on our track with lots of technical jumps, I'm going to back to the stock chassis. And in all seriousness, the eb410/et410 are a blast to drive. I still run my eb410/MIP, as it is whips in the corners like no others. But it does not drive like a eb410/et410.
Lame Tekno does not care enough to share with it's customers, some of the Pro setups. One reason my sct410.3 is going on ebay. I like comparing my setups to the Pro's, for some ideas.
sea1swk is offline
