LC Racing EMB-1H Official Thread >
Like Tree620Likes
Old 01-06-2019 | 05:05 PM
  #1651
Here's my car. I had a few sets of the carbon bits made. The carbon is 1mm thicker than the LC stuff. I also added an additional camber hole on the rear to add a roll center option.
scoobyrs25 is offline
Old 01-07-2019 | 08:41 AM
  #1652
racknpinion's Avatar
That looks great! Are you running 4wd buggy fronts all around? Love those custom carbon towers.
racknpinion is offline
Old 01-07-2019 | 10:08 AM
  #1653
Cain's Avatar
you interested in making more for sale?
Cain is offline
Old 01-07-2019 | 03:17 PM
  #1654
Thanks. They are 2wd front and 4wd front on the rears, cut down and glued back together. Proline did a how to video.
boogersrevenge likes this.
Old 01-07-2019 | 03:19 PM
  #1655
sure
Cain likes this.
Old 01-08-2019 | 09:03 AM
  #1656
Cain's Avatar
Originally Posted by scoobyrs25
sure
Cool, what else can you make? An item that I know some of us would want in carbon fiber would be the top deck, just a better material / slightly thicker for both the standard buggy and the truggy.
Heck, if it was possible to get some machined hangers with more insert options would love that.
Also, maybe some carbon lockouts for the slipper?
Cain is offline
Old 01-08-2019 | 11:16 AM
  #1657
One thing I'd really love to see is an improved steering rack with some small bearings instead of bushings, or having resort to ditching the bushings and using flat head hex screws to lessen play. Making it out of CF would be awesome. Maybe outside the scope of what you're able to do, but it would be a great hop up.
Old 01-08-2019 | 04:21 PM
  #1658
I did a top deck for the long chassis. I wanted it to be more flex, but pretty sure it's stiffer. Hangers would be cool and easy, but the inserts would be difficult. I'm not sure how durable or useful it would be. I'll look into it.
Old 01-08-2019 | 04:23 PM
  #1659
I've played with this idea a bit. I'd like to be able to correct the bump steer too. I was able to fix much of the issue using a lower profile Lunsford ball studs.
racknpinion likes this.
Old 01-10-2019 | 05:23 AM
  #1660
Vcoupe's Avatar
If you make/ sell CF bits I’m in. I’d also like to see them 1mm thicker. I just bought a truggy and compared it next to my Losi and the LC has much thinner parts everywhere.
Vcoupe is offline
Old 01-10-2019 | 05:28 AM
  #1661
Vcoupe's Avatar
Anyone running the aluminum hubs front and rear? Worth it? What about the aluminum bellcrank?
Most importantly, I’ll experiment here but I’d like to replace those crappy ball/ rod ends with the screw type like on 1/10++ sized cars. Anyone have a definitive setup? I have Lunsford ti turnbuckles and rpms on my Losi but I also wanted to convert that car over too.
Vcoupe is offline
Old 01-10-2019 | 12:13 PM
  #1662
Cain's Avatar
I run the hubs front and rear and the bellcrank.
Both sets hold up well. The aluminmum bellcrank seems to help with some slop on the front end for the higher traction we run on.
As for setup, what conditions are you running on?
In general here guys like 7K front and 3K rear or 5K front and 3 or 2K rear with rally style tires we use. This is on carpet.
Cain is offline
Old 01-10-2019 | 06:01 PM
  #1663
I'm running all the aluminum and love it. With some shimming to take up slop it is a tighter, more consistent handling car. You might notice a little more slop once you add the aluminum parts, but that can all be addressed. A pack of 4mm and 2.5mm shims comes in super handy with these cars from my experience, which is not a knock on their quality at all. The rear aluminum hubs also eliminated the lopsided toe-in on the left rear side. Easy fix with the pill inserts but the aluminum hubs cures it too.
Old 01-11-2019 | 07:02 AM
  #1664
I only like running one of the two options up front. I think it helps with fitment and durability. Traction is always higher with plastic parts in loose situations as well.
Old 01-11-2019 | 03:22 PM
  #1665
Tires, diff fluid, shocks and droop will do far more for tuning and traction than a plastic C hub or spindle could in my experience.
Some flex is certainly understandable from a handling perspective, but a lot of this also comes down to personal preferences. I personally prefer stiffer arms and hubs/spindles. On asphalt and higher grip surfaces, the car is much more neutral and consistent feeling too me. Not a huge difference, but it’s there. The stiff arms are actually one of the best hop ups you can get for these cars in my opinion, but anytime you increase the stiffness of these parts, you can expect a less forgiving drive to some extent.
You can also do a simple bearing friction test with the plastic parts and aluminum and see the resistance increase with the plastic parts. Stick an axle through them both and use the same bearings them give them a spin. See what you think.
That’s been my experience anyway.
