LC Racing EMB-1H Official Thread
#1501
I’d steer clear of those chop shop ESC’s. Especially on one that’s based on an old design and wasn’t that great to begin with. Hobbyking is usually just cheap clones of other stuff, though there are a few exceptions. A legit HW 16BL30 can be had for less than $20.
#1502
#1504
As of right now, the Leopard is probably the best sensored motor for the LC's just due to the size and reliable performance, but there are also smaller 24mm sized motors from Carisma and Hobbyking as well, which I see a lot of racers using. They have one advantage over the Leopard, and that is a removable sensor wire. LC have shown teaser shots of a Hobbywing 2850 sensored motor they are woking on, but nothing has appeared for sale yet. That is the one I am dying to get my hands on.
#1507
Carisma motor has 3mm shaft which will need new pinions (and it is +$25 pricier than Leopard). Do I understand right that the smaller size results in possible heating problems?
And where did you find that teaser from LC - I’d like to subscribe for their news, but in Facebook there were no info about new motors.
#1508
#1509
I am currently running the Leopard sensored motor in my LC Racing EMB-T with the Hobbywing WP10BL60 sensored esc, and this power system is nothing short of amazing in that. It is smooth, runs cool and way more power than this thing really needs. I can do backflips on 2s.
#1510
Hmm, and for what issues or benefits are removable sensor wires usually done? Is it for cases when you have sensorless esc or are there any other reasons to chose it?
The Carisma is a 24mm motor, true. And yes, the pinion is 3mm so you need to use their pinions. But it is also only $30 on Amazon, so almost half the price of the Leopard. Would the small size be an issue? Perhaps. Almost definitely for the truggy, but there are LOTS of people running the Trakstar clone of this in their buggies and LWB buggies, esp in the European racing circuits. Put a fan on it, and on a small track for mini racing, you're golden. Probably not the best choice for bashing though.
Here's the pics from whatever hobby trade show they showed this at in China around April. I know it's a real Hobbywing motor because I asked and they confirmed it. They did not however tell me if they were working with Hobbywing to offer this exclusively for the LC's or if this was something Hobbywing was working on independently. I'm sure if it *ever* is released as an official product, it will be added to the HW website. One can hope anyway.
#1511
Just some pics of how mine is currently sitting. Still loving it.
LC Racing EMB-TGH ARR
Tenshock 1401 4850kv motor
19t pinion 60t stock spur
Hobbywing sensored 10BL60
KO RSX-12 servo
Hangar 9 servo horn
LC Racing full aluminum kit
LC Racing carbon top brace
LC Racing hard suspension arms
Avid bearing kit
TBR bumper
Double bearing mod on rear diff pinion assembly
Ball bearing in spur gear
Shimed steering rack bushings
Losi 27.5 shock oil
Jconcepts Rulux 2.2
Jconcepts Goosebumps
Venom and Lectron Pro 2s
KO RSX-12 servo
Hangar 9 servo horn
Avid bearing kit
TBR bumper
Losi 27.5 shock oil
Jconcepts Rulux 2.2
#1512
Thanks! It's just a glitch buster. Theres lot of brands that make them, but that one is made by Racers Edge. Commonly used when high voltage servos draw to much juice and cause certain receivers to glitch or brown out. I had neither of those issues, but it did improve the feel of the car. I've had people tell me it should make zero difference, but that has not been my experience. Cheap thing to try for yourself.
#1515
Well, still not allowed to use images in the post ... But there are four in my profile, album 'My Post Picture'.
First image: Found some direct fit lipos for short wheel base at HK. No modification of the battery holders necessary.
Second: The look won't last long.
Third: Lesson learnt: Never leave your buggies unattended in the basement. And 2WD seems to be recessive.
Fourth: And the electonics' side.
Only issue during the build: I over tightened the screws at the steering posts and the top deck cracked. Steering was to tight and the servo moved the saver some way until the wheels moved. Driving straight ahead? Forget it! Put two shims in there and now it works fine.
620Likes
