Polypro Pinion set screw size >
Like Tree2Likes
  • 1 Post By EbbTide
  • 1 Post By millsj2
Old 07-18-2017 | 09:51 AM
Default Polypro Pinion set screw size
Does anyone know the size of the polypro set screw? I'm trying to find a allen wrench for mine and I don't know the size I need.
millsj2 is offline
Old 07-18-2017 | 09:53 AM
EbbTide's Avatar
You need a .050" driver
millsj2 likes this.
EbbTide is offline
Old 07-18-2017 | 09:54 AM
Thumbs up
Thanks for the quick response! Ordering an MIP driver now
EbbTide likes this.
millsj2 is offline
Old 07-18-2017 | 10:18 AM
JAE
More importantly where can one buy extra grub screws as these are easy to lose thx
JAE is offline
Old 07-18-2017 | 10:28 AM
EbbTide's Avatar
That is a very good question lol. I'll have to use my screw measuring meter at home to see if I can find the size.
EbbTide is offline
Old 07-18-2017 | 10:38 AM
MarkA's Avatar
I haven't tried it firsthand but I was once told that those screws can be found as an old inch-sized AE part.
MarkA is offline
Old 07-18-2017 | 11:09 AM
EbbTide's Avatar
Dang I wish I'd seen this sooner. Just placed an amain order and would have tried these for our benefit lol.
Edit: I'm dumb. I forgot I had the screw tray with metric only measurements instead of both... I can't confirm the size, for now.
EbbTide is offline
Old 07-19-2017 | 08:47 AM
darksiede's Avatar
.050 is also the same as a 1.3mm if I recall..
darksiede is offline
Old 07-21-2017 | 05:58 PM
racer1812's Avatar
Super Moderator
I've never had a pinion set screw be .050, they've always either been 1/16 or 1.5mm
racer1812 is offline
Old 07-21-2017 | 05:59 PM
racer1812's Avatar
Super Moderator
1.27mm technically
Old 07-21-2017 | 06:05 PM
racer1812's Avatar
Super Moderator
By far the most common set screw size for pinions is 1/8 inch with a 4-40 pitch using a 1/16th allen wrench.
Not including metric 48p pinions (most often used by Tamiya) Some do use a metric set screw (Traxxas) that use a 1.5mm allen wrench..
Old 07-22-2017 | 02:35 PM
Pretty sure TLR pinions are also 1.5mm
SlashBash10 is offline
Old 11-30-2018 | 11:06 AM
Sorry to revive an old thread.
Can anyone confirm that a .050 driver fits the PolyPro pinion set screws? I have two of these and have tried two different high quality .050 drivers and both are a loose fit. I contacted 17.5RC and they insisted that .050 was the correct size and would not tell me the thread size of the set screw. I even took the pinions back to the shop I purchased them at. They tried every driver they had metric and standard and not a single one fit properly. Thanks in advance.
Rlmxracer is offline
Old 11-30-2018 | 11:10 AM
Yes, it's .050
K.Kincaid is offline
Old 11-30-2018 | 04:44 PM
Yes, it's .050
that's odd because neither of the machined tip .050 drivers fit snugly and will end up stripping the set screw. I guess I will have to find replacement set screws that actually work with my drivers.
