Like Tree6Likes
Sanwa 481/482
Old 04-10-2018 | 12:49 PM
Default Sanwa 481/482
Looking at the two what is the difference? Anyone know that could shed some light on this matter. Thanks
mattythegreat is offline
Old 04-10-2018 | 01:06 PM
EbbTide's Avatar
The RX481 does not have telemetry
And the RX482 has telemetry with the SSL function on compatible remotes.
mattythegreat likes this.
EbbTide is offline
Old 04-10-2018 | 04:47 PM
They perform exactly the same. The only difference is that if you have one of Sanwa's overpriced escs, you can program it from some transmitters. I would get whatever is cheaper.
rcbuggy88 is offline
Old 04-10-2018 | 05:06 PM
JayL's Avatar
<br />
<br />
Or,
If you have one of the new PGS servos, you can program it.
JayL is offline
Old 04-11-2018 | 04:40 AM
I see both are about the same price point. Gonna run nitro, is telemetry worth doing In nitro?
Old 04-11-2018 | 09:04 AM
What class would this be? Offroad or onroad? offroad you would probably want a receiver with an antenna such as the rx-471/472. If going onroad, either is fine. I would get the cheapest one.
Old 04-13-2018 | 11:16 AM
nitro truggy would be the class. Why would I need an antenna? Do they get further reception ?
Old 04-13-2018 | 11:48 AM
EbbTide's Avatar
Just a heads up, only certain Sanwa receivers can actually do telemetry for nitro. You'd need this receiver
https://www.amainhobbies.com/sanwa-a...41095a/p500051
And then you'd need to buy telemetry attachments like these
https://www.amainhobbies.com/sanwa-a...41061a/p500050
https://www.amainhobbies.com/sanwa-a...41051a/p500049
EbbTide is offline
Old 04-13-2018 | 03:57 PM
I personally don’t want it the telemetry. What’s with the antenna Though. Should I have one or not? That’s all I am concerned about.
Old 04-13-2018 | 04:03 PM
EbbTide's Avatar
well the wireless receivers have a shorter range so on very large tracks there is a possibility you could lose signal at the furthest point on the track. However just being a nitro car won't prevent you from using it. So the wireless one will work you just need to test your range if the tracks you run on are especially large
EbbTide is offline
Old 04-13-2018 | 06:17 PM
Default 482
I run the 482 in both my nitros on large tracks and have never had any problems, they are great, it’s nice not having to deal with the antenna, I run the 482 with my m12s, and I can get the telemetry for what my battery voltage is at!
jakeg1973 is offline
Old 05-27-2019 | 03:49 AM
What’s the range of the rx-482 receiver ? I bought new mt44 transmitter and it came with 482. Some says the internal antenna range is low. I have savage flux & gp 1/5 hpi baja. I’m afraid where they lost the signal.
thanks
edit : and which one is the better
sanwa mt44 with rx482
futaba 4pv with r304sb
Sayginss is offline
Old 09-26-2019 | 01:24 PM
Sorry to revive this thread but was hoping to get some answers on the range expectancy for the RX482?
I have it installed in a Tekno MT410 and it can make it about a block before I run out of range. Just wanting to see if this sounds normal or if I should be expecting more/less.
notlimah is offline
Old 09-26-2019 | 08:36 PM
uDi_MP7.5's Avatar
With my 482s I can lose sight of the car before I lose range, might vary depending on environment but it's a non issue to me.
There are some mounting instructions in the Sanwa manual which might be useful to check.
Good riddance to antenna wires!
uDi_MP7.5 is offline
Old 09-27-2019 | 08:52 PM
What car is this in? All flat terrain?
I read through the manual thoroughly and most of the ‘cautions’ seem unavoidable. I did my best mounting it as far away as possible from anything that could interfere as well as as high as possible. Seems like this might just be the range I’ll have with this vehicle.
notlimah is offline
