Xray X1 - Formula One Car >
Like Tree366Likes
Old 04-10-2018 | 05:07 PM
  #2521
JayL's Avatar
Originally Posted by RedBMaster
Yes, its a full sealed gear diff! Its butter smooth and will pretty much change the game. I predict by the end of the year we'll all be running a locker or the gear diff!
<br />
<br />
Agree, unless people ban it because it costs too much
phatboislim likes this.
JayL is offline
Old 04-10-2018 | 08:54 PM
  #2522
Dan's Avatar
Dan
Picture of AE pivot with cut ears. Everyone knows when you mix blue and orange, your car goes 0.2 secs slower a lap.
chensleyrc1 and Ph3nyx like this.
Dan is offline
Old 04-11-2018 | 06:55 PM
  #2523
Khador12's Avatar
You can also get this one from Zen racing. Associated Style Rear Slide Pivot Mount, Zen Racing
Khador12 is offline
Old 04-17-2018 | 10:23 AM
  #2524
DirkW's Avatar
Martin Hudy teased a picture on Facebook on what appears to be a new gear diff. From the look of things, could be sealed and possibly lighter than the Fenix diff.
Haven't actually bought the Fenix Diff yet... might be worth waiting for this one.
DirkW is offline
Old 04-19-2018 | 03:05 AM
  #2525
Originally Posted by Darkgenerals
That's a fair price, I payed a little bit more for my 2015 with side pod upgrades. You can still get parts and 2018 parts will fit, but it's not worth upgrading everything.
Jumped the gun and bought it. This kit will be my introduction into F1 and re-entry into RC. Thanks DarkGenerals for your reply.
Not sure if it's box stock or if upgrades have been done to it. First step: taking it apart and putting everything back together again following the manual. Actually, first step: waiting for the tools I need to take it apart to arrive. Also wondering what state the batteries it came with will be in.
From what I have read so far tires seem to be 90% of a good set-up.
Does anyone have experience with the volante tires used in the ETS?
And some newbie help on tire additive?
Will be racing outdoor first.
Stinj is offline
Old 04-19-2018 | 10:07 AM
  #2526
Blakesrc's Avatar
From: Pismo Beach, CA -Montgomery, TX - Maryville, TN
Hey Guys, I've been running my '18 with the kit setup on black carpet for a few weeks now and it is working well other than the occasional traction roll during the first 2 minutes of a race. I have my front sidewalls glued up to about 1mm from the seam where the sidewall meets the rolling surface of the tire, should I go higher? I have tried increasing and reducing the rear droop, softer front springs and several different tire sauce methods front and rear and the only thing that really seems to cure it is no sauce but then I run into a pretty bad push. Any other suggestions?
Blakesrc is offline
Old 04-19-2018 | 10:14 AM
  #2527
Adamska27's Avatar
I glue all the way up to the tread both front AND rear on my F1 tyres...
But first maybe try softening up the swaybar by mounting the links further down the bar (further from the pivot axis = softer)
1mm difference in swaybar mounting seems to make a big difference in handling for me
Adamska27 is offline
Old 04-19-2018 | 10:44 AM
  #2528
Anyone running Fantom 25.5T team works plus motor (best option)? Do you really see any difference worth sticker price of this motor in this class? Thx
onenext is offline
Old 04-19-2018 | 11:26 AM
  #2529
F N CUDA's Avatar
I've found that the Pit 571 front tires do just that.
Grip roll for the first several laps then settle in perfectly then push like mad.
UF1 used to race 15 min mains and by the end of the main the car would not turn at all.
I went to the Pit 574 front tires and what ever you started out with sauce wise was what you got for the whole race.
i.e. if you grip roll at the start, you'll grip roll til the end, get it right and it's right til the end.
Full side wall glue AND full sauce up front and my Xray was good to go.
Note: that was gray carpet days, haven't had the pleasure of running black carpet, yet.
F N CUDA is offline
Old 04-19-2018 | 08:11 PM
  #2530
Darkgenerals's Avatar
I would see what the locals are using for sauce and tire manufacturer.
freebird likes this.
Darkgenerals is offline
Old 04-21-2018 | 12:28 PM
  #2531
JEFFs SC10's Avatar
The motor is good, but a great motor is useless if your setup isn't right and your driving lines are off. Get the setup right , make the car very easy to drive first, consistently place top 5 and then if you can't get any better then buy the great motor and batteries.
Tim Neja likes this.
JEFFs SC10 is offline
Old 04-22-2018 | 05:44 PM
  #2532
This is true.
Save your money. Wrench on your car until you know every setting and how it changes your car. That and practice. Don't think about what pack you should buy. Think about running as many packs as possible.
New lipos and motors can't overcome a sloppy line
tekin112000 is offline
Old 04-22-2018 | 07:09 PM
  #2533
carrizojim's Avatar
Originally Posted by tekin112000
This is true.
I don’t agree, I don’t have money to be buying everything twice. I buy good stuff and take care of it. You will get fast.
carrizojim is offline
Old 04-24-2018 | 12:14 AM
  #2534
Default Yep!!
Originally Posted by bertottius
Generally, the thought on no drag brake is that you can carry more speed through the corner if you're not braking where it isn't necessary. Work on getting the car to turn with the chassis setup rather than using drag brake.
that sounds good Bert, I'll give that a try also.
XrayAllDay1 is offline
Old 04-26-2018 | 01:25 AM
  #2535
A few tips. No sway bar. I know no one running it on black carpet successfully. Run the cross brace on the A-arms. Also, try the optional wider arms, they help. For front springs I ran the XRay gold softs and xray gold soft side springs with 12k in the tubes and 2.5 million in the gear diff.
chensleyrc1 is offline
