Cooling FAN
Old 02-02-2018 | 05:23 AM
1fastdude's Avatar
Default Cooling FAN
What fans are some racers using for cooling the ESC for mod in 1/12 scale?
1fastdude is offline
Old 02-02-2018 | 05:48 AM
Skiddins's Avatar
Whatever you can get to fit under the body, usually a 25mm or maybe 30mm.
Usually on their side pointing at the ESC as there's seldom room on top of the ESC.
Skiddins is offline
Old 02-02-2018 | 05:53 AM
1fastdude's Avatar
Any specific brands, or are they all about the same?
Old 02-02-2018 | 06:56 AM
aracefan's Avatar
Are you sure you need one? Generally, geared right, you shouldn't need a fan to run 17.5 or mod - for your motor or your speedo... Are other people running an ESC fan where you race? I would just run what someone you race with is running (or something similar anyway) as I've never seen a fan on a 1/12th scale when I run it... Good luck with it.
aracefan is offline
Old 02-02-2018 | 07:13 AM
Laguna Bozo's Avatar
You shouldn't really need a cooling fan unless you terribly over-gear your car. BUT, that's exactly what racers do, over-gear the poo out of their cars in the quest to go faster and win. Crazy, isn't it?
Laguna Bozo is offline
Old 02-02-2018 | 07:33 AM
Skiddins's Avatar
Originally Posted by aracefan
....you shouldn't need a fan to run 17.5 or mod - for your motor or your speedo...
Correct for 17.5, but you almost certainly need one for open Mod.
Never even seen a fan for the motor in 1/12
Skiddins is offline
Old 02-02-2018 | 07:35 AM
1fastdude's Avatar
OK, thanks for the input. I think that i found my answer.
Old 02-02-2018 | 11:51 AM
Marcos.J's Avatar
Super Moderator
And with that post we can lock is topic
Marcos.J is offline
