-   -   Cooling FAN (https://www.rctech.net/forum/radio-electronics/1009526-cooling-fan.html)
1fastdude 02-02-2018 05:23 AM
Cooling FAN
What fans are some racers using for cooling the ESC for mod in 1/12 scale?
Skiddins 02-02-2018 05:48 AM
Whatever you can get to fit under the body, usually a 25mm or maybe 30mm.
Usually on their side pointing at the ESC as there's seldom room on top of the ESC.
1fastdude 02-02-2018 05:53 AM
Any specific brands, or are they all about the same?
aracefan 02-02-2018 06:56 AM
Are you sure you need one? Generally, geared right, you shouldn't need a fan to run 17.5 or mod - for your motor or your speedo... Are other people running an ESC fan where you race? I would just run what someone you race with is running (or something similar anyway) as I've never seen a fan on a 1/12th scale when I run it... Good luck with it.
Laguna Bozo 02-02-2018 07:13 AM
You shouldn't really need a cooling fan unless you terribly over-gear your car. BUT, that's exactly what racers do, over-gear the poo out of their cars in the quest to go faster and win. Crazy, isn't it?
Skiddins 02-02-2018 07:33 AM
Originally Posted by aracefan (Post 15146868)
....you shouldn't need a fan to run 17.5 or mod - for your motor or your speedo...
Correct for 17.5, but you almost certainly need one for open Mod.
Never even seen a fan for the motor in 1/12
1fastdude 02-02-2018 07:35 AM
OK, thanks for the input. I think that i found my answer.
Marcos.J 02-02-2018 11:51 AM
And with that post we can lock is topic:)
