Best way to install throttle return spring? >
Like Tree6Likes
Old 12-04-2016 | 09:59 AM
  #16
ROSCOE's Avatar
Yep, but hasn't happened yet. Throttle linkage setup and a good cup should help to prevent that. I posted the picuture as it is an idea that works for me and hasn't let me down. Matter of fact I've had 100% more failures in bands than throttle linkage popping off. Just saying.
ROSCOE is offline
Old 12-04-2016 | 10:16 AM
  #17
HaulinBass's Avatar
you could always run both, the elastic doesn't have to be very stretched out because it just needs to hold the carb closed if the linkage falls off so it should last longer. then your covered in any case besides a servo locking up
HaulinBass is offline
Old 12-11-2016 | 04:02 PM
  #18
Any disadvantages when using elastics or springs for closing carb? Heat build up in the servo or excessive stress when elastics are too tight?
Kibble is offline
Old 12-11-2016 | 05:57 PM
  #19
mercfocus's Avatar
That question right there is why I've never run anything to close my carb. The local track is too far me so I never needed to meet any kind of rule requirement.
But now I have this brand new $150 Futaba servo that's real twitchy and had a runaway with another car a while back so between those 2 things, I'm trying to start using return springs.
I just got my Dynamite springs in the mail Friday and they look a lot better then the Nova springs so hopefully at least maybe I can now do something about the twitchy servo.
All my servos I run for T/B are at least 180/oz so I guess they're strong enough to tolerate the extra load?
Last edited by mercfocus; 12-11-2016 at 05:58 PM. Reason: Forgot to mention other car was runaway.
mercfocus is offline
Old 01-16-2018 | 07:52 AM
  #20
sorry to resurrect this thread but Im using, well attempting to use the Goody's bands and well its not closing the carb. Anyone have a picture on how they're running them? All of the photos on here are not showing up (photobucket)
Thanks.
Evoking1230 is offline
Old 01-16-2018 | 09:36 AM
  #21
jasburrito's Avatar
Not mentioned. But I will add. Choose a digital cordless servo that moves really easy when not powered.
jasburrito is offline
Old 01-16-2018 | 09:53 AM
  #22
Yea seriously, I have a Spektrum 605 that doesn't move when cutting power to the onboard electronics :-(
I'll try to see if my Savox will be a little more forgiving and give up lol
Old 01-17-2018 | 01:12 PM
  #23
thats a negative on the Savox lol
Old 01-18-2018 | 01:39 PM
  #24
p.hat's Avatar
get yourself a futaba servo
p.hat is offline
Old 01-18-2018 | 01:51 PM
  #25
Id rather not without knowing 100% for sure it would give up to some sort of return
And besides, I have a Savox for steering, gotta match!
Old 01-18-2018 | 02:49 PM
  #26
HaulinBass's Avatar
Futaba coreless digis turn like butter with no power. I have an old bls351 that could probably be closed with a good hard breath with no power applied
Old 01-18-2018 | 03:34 PM
  #27
p.hat's Avatar
i know that feeling, always gotta match haha
p.hat is offline
Old 01-18-2018 | 03:51 PM
  #28
Usually it doesn't have to close the throttle completely when the engine is off, ones the engine is running the vibrations will help close it, test and see.
And I'm not sure what you're using to help close, but I don't have problems with Savöx.
NitroVein is offline
Old 01-18-2018 | 06:19 PM
  #29
I have a Spektrum 605 (came with the RTR) for throttle/brake and a Savox for steering duties. The Savox did not return for me
Old 01-19-2018 | 07:22 AM
  #30
You might need something slightly stronger then. I'm using a spring and it's not strong at all, it doesn't close the throttle completely when the engine is off, but with vibrations it will close it pretty quickly.
Just a thought, if you had the servo for some time it might need to be serviced, it can collect a lot of dirt inside.
