Best way to install throttle return spring? >
Like Tree6Likes
Old 01-19-2018 | 01:54 PM
  #31
Originally Posted by NitroVein
You might need something slightly stronger then. I'm using a spring and it's not strong at all, it doesn't close the throttle completely when the engine is off, but with vibrations it will close it pretty quickly.
Just a thought, if you had the servo for some time it might need to be serviced, it can collect a lot of dirt inside.
The spektrum servo is waterproof, and apparently dust proof. I opened it up and no dust
I got for S&G's a Dynamite Throttle Return Spring. For $2.45, its a no brainer. If it doesnt work the way it was intended to work, I'll try to retrofit it. Like I said, for under $3 bucks, doesn't hurt to try!
Evoking1230 is offline
Old 01-19-2018 | 08:37 PM
  #32
Goof's Avatar
Default Rs
Works well nova springs
Attached Thumbnails Best way to install throttle return spring?-20170628_101812.jpg   Best way to install throttle return spring?-20180119_204150.jpg
Goof is offline
Old 01-20-2018 | 05:54 AM
  #33
Originally Posted by Roelof
Small hairbands are perfect.
This is the best method. Never had one break and no stress on the carb.
Chris Reilly is offline
Old 01-20-2018 | 07:02 AM
  #34
I ve used the dynamite spring for years and its never tore the carb boot on any of 21's it a personal thing I know! Michael
stoney452 is offline
Old 01-20-2018 | 01:42 PM
  #35
Thank you for posting a pic.
I'll let everyone know how it goes with the Dynamite spring or if I needed to do something similar to this
Old 01-21-2018 | 08:58 AM
  #36
Old 01-26-2018 | 03:43 PM
  #37
Goof's Avatar
Default R s in a nb48.4
This works way better then those goodie hand bands....
Attached Thumbnails Best way to install throttle return spring?-20180126_153940.jpg   Best way to install throttle return spring?-20180126_154001.jpg
Goof is offline
Old 01-26-2018 | 03:53 PM
  #38
petersen114's Avatar
Not picking, but this still won't stop a runoff.
petersen114 is offline
Old 01-26-2018 | 04:46 PM
  #39
Better to have it connected to the throttle.
NitroVein is offline
Old 01-26-2018 | 05:24 PM
  #40
Goof's Avatar
Y wont it... if I hold it open and unplug it it closes.... and iv pratices so long my battery died and nuthing happen so sure if your ball cup is worn or if it pops off u still can steer in a circle but it didn't run crazy like I have seen ... do it or not it has work great for me or i wouldnt have shared it
Goof is offline
Old 01-26-2018 | 05:42 PM
  #41
Goof's Avatar
Default Rs
Iv try it many ways this is the best way for me ...
Goof is offline
Old 01-27-2018 | 03:03 AM
  #42
Run it as you wish, just pointing out that it isn't a fool prof way of doing it, if someone else reads it.
If you got holes in the head, just attach it there and put a regular screw in place of the set screw on the throttle, then it will do the job no matter what happens.
Old 01-27-2018 | 10:33 AM
  #43
Goof's Avatar
It's rc nuthing is fool proof iv had the spring brake before the zip tie I always check it ... as u should... just post a pic and stop point out the bad in mine.....
that donest give enough tension on the spring for me thats y I use the zip tie
Goof is offline
Old 01-27-2018 | 11:10 AM
  #44
If you get offended by someone giving some friendly advice on a forum, then this isn't the place for you...
Will see if I got a picture, but as I explained it detailed I'm not sure it's needed to understand.
Old 01-27-2018 | 11:19 AM
  #45
The only picture I could find at the moment.
