Need help please!
I just installed the HOBBYWING QUICRUN 1060 Brushed 60amp ESC! When I turn it on I can only turn the wheels and can’t get and throttle response! I’ve got the TITIAN 12T550 motor and a SPEEDPACK 3300mAh 7.2v Ni-MH battery
Be sure LVC is disabled.. might have to move jumper settings as shown in manual
it should auto calibrate every time the ESC is turned on... very important not to move the throttle during the calibration sequence when it's turned on... wait for the series of beeps to indicate cell count and then it's ready to go.
Originally Posted by HobbyWing Manual
Calibrate the throttle range. Turn on the ESC switch, set the throttle stick to the neutral point and then wait 3 seconds for the completion of throttle range self - calibration; Beep sound emits if the self - calibration is successfully passed, then the ESC is ready to run.
