JQ Products "White Edition" >
Like Tree3Likes
Old 03-05-2017 | 07:39 AM
  #3496
ozziii's Avatar
Does it mount in the same place as the plastic one or is it longer, similar to the Black Edition chassis brace. I think they need to be longer & mount on the chassis up beside the engine mount somewhere to reduce the chassis flex, like the B.E.
ozziii is offline
Old 03-05-2017 | 12:01 PM
  #3497
UrabusDenis's Avatar
On the same place as the plastic one, just with two screws on the chassis
UrabusDenis is offline
Old 03-06-2017 | 05:31 AM
  #3498
ozziii's Avatar
I think the short brace is the problem, not sure if 2 screws will make much of a difference, will be interesting to see how it works for you though.
On another subject, does anyone know where I can find the pics & info showing where to grind the front arms for more droop, just want to check & make sure I'm getting it done properly.
ozziii is offline
Old 03-06-2017 | 07:55 AM
  #3499
Here it is
THE WE LV Setup Guide ? JQRacing
Old 07-24-2017 | 06:03 PM
  #3500
I just upgraded my W.E. with LV parts and used the LV kit setup. My rear outer camber link ends rub the inside of the wheels pretty good. Anyone else experience this?
Banshee8530 is offline
Old 07-25-2017 | 12:45 AM
  #3501
speedy2's Avatar
did you use all the LV parts ? rear uprights, rear toe/squat plates and tower
speedy2 is offline
Old 07-25-2017 | 06:45 AM
  #3502
Weird, people have experienced this with the Black Edition geometry and new Schumacher astro tires, but not before. As asked, did you use the whole LV rear? It's all combined
Old 07-25-2017 | 06:08 PM
  #3503
Yes, R-F and R-R hinge pin blocks (both orange), LV rear tower, and LV Hubs right and left. Did I miss something? I have the camber links mounted in the top middle hole on the hubs. Wheels are old Avid with AKA enduros mounted.
Old 07-26-2017 | 01:14 AM
  #3504
ttr_racer's Avatar
Yes, I too had that problem. I was using Jconcepts wheels and they rubbed a flat spot on the upper link from rubbing the wheel
ttr_racer is offline
Old 07-26-2017 | 05:45 PM
  #3505
I just installed a set of pre-mounted AKA tires and wheels. They rub, too, but much less than the old set I had on there.
I think the age of the wheels/tires combined with my local climate might have something to do with it (low humidity and high-ish elevation). A little shrinkage of the rubber and plastic can be expected over time.
Old 07-29-2017 | 04:33 PM
  #3506
Kyosho Kid's Avatar
Did you install the end links upside down?
Kyosho Kid is offline
Old 07-29-2017 | 04:35 PM
  #3507
Nope. It's just the large OD around the ball socket that hits. I'll likely be dropping the link to the lower holes for low traction anyway, so no big deal.
Old 11-24-2017 | 11:57 AM
  #3508
Default White edition ELECTRIC converted
So I have a WE converted electric with factory e conversion from JQ. Ive been searching and searching on here for what type of bodies fit car. I know bittyforce has one, but any other ones? Thanks in advance
Mikeymike954 is offline
Old 11-24-2017 | 02:01 PM
  #3509
Kyosho Kid's Avatar
Mp9 mbx7r xb8
Old 11-24-2017 | 03:44 PM
  #3510
Originally Posted by Kyosho Kid
Mp9 mbx7r xb8
Thanks bud, appreciate it. Do I get the nitro version of the bodies or electric?
