JQ Products "White Edition"
#3496
Does it mount in the same place as the plastic one or is it longer, similar to the Black Edition chassis brace. I think they need to be longer & mount on the chassis up beside the engine mount somewhere to reduce the chassis flex, like the B.E.
#3497
On the same place as the plastic one, just with two screws on the chassis
#3498
I think the short brace is the problem, not sure if 2 screws will make much of a difference, will be interesting to see how it works for you though.
On another subject, does anyone know where I can find the pics & info showing where to grind the front arms for more droop, just want to check & make sure I'm getting it done properly.
#3499
#3501
did you use all the LV parts ? rear uprights, rear toe/squat plates and tower
#3502
Weird, people have experienced this with the Black Edition geometry and new Schumacher astro tires, but not before. As asked, did you use the whole LV rear? It's all combined
#3505
I just installed a set of pre-mounted AKA tires and wheels. They rub, too, but much less than the old set I had on there.
I think the age of the wheels/tires combined with my local climate might have something to do with it (low humidity and high-ish elevation). A little shrinkage of the rubber and plastic can be expected over time.
#3508
White edition ELECTRIC converted
So I have a WE converted electric with factory e conversion from JQ. Ive been searching and searching on here for what type of bodies fit car. I know bittyforce has one, but any other ones? Thanks in advance
#3510
