Tekno RC EB410 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree2421Likes
Last edit by:
Print Wikipost
Old 11-19-2017 | 01:38 PM
  #2431
RazorRC's Avatar
EB410 full review is up.
+ YouTube Video
fireflysti and billdelong like this.
RazorRC is offline
Old 11-19-2017 | 01:40 PM
  #2432
Originally Posted by charvel74
I'm running on high bite carpet. Ricochet raceway.
I'm currently at 1760 grams. With all stock setup. I ordered carbon fiber battery strap, carbon fan mount ,front and rear towers and front brace. Should drop a good amount of weight
charvel74 is offline
Old 11-19-2017 | 01:52 PM
  #2433
Matthew_Armeni's Avatar
You definitely don't need the screw kit, especially on carpet where a really low weight isn't needed. The bearing kit from RC Speed Secrets is a surprisingly big difference though. I'd get that and things to increase your durability like Lunsford links.
Matthew_Armeni is offline
Old 11-19-2017 | 01:57 PM
  #2434
Originally Posted by E-Mann
I have both and plan on only running the Tekno in the future.
Thanks for your input, Durability and ease of use are going to be my big to factors for me since I'm so new. Just trying to but together a buy list. I will need a 13.5 motor as far as electronics go, and then whatever replaceable parts I may need on hand as I break things.
Justin805 is offline
Old 11-19-2017 | 02:06 PM
  #2435
cool I'll try those out
Old 11-20-2017 | 05:47 AM
  #2436
Racerx336's Avatar
Got to drive the EB410 this weekend and car was awesome. Was able to TQ and win 13.5 4wd at round one of Tyler Hook's Southern Winter Payout Series. Ran Mason's Surf City setup with 15k and 7k diff setup with a center Exotek locker. Car was awesome all day with qualifying times that would have put me 4th in the Mod 4wd A. Car weighed in at 1654.
billdelong, Mononga and charvel74 like this.
Racerx336 is offline
Old 11-20-2017 | 09:25 AM
  #2437
Congratulations on winning Hooks race for 13.5 4WD. I plan on entering when it comes to Thornhill. When you used the Exotek locker did you use the spur that came with it 75T or did you go with a smaller one. What spur and Pinion combo did you go with. I tried it out last weekend and I used 75-27. It felt good but I feel I need to change the gearing. Thanks.
Mononga is offline
Old 11-20-2017 | 09:29 AM
  #2438
Originally Posted by Justin805
I want to buy a 4wd for 13.5 stock racing. I haven't been racing long 5 Races 10 Practices mostly w/ a short course and a buggy 2wd both associated. I recently moved and have a new track to get used to. I'm looking at both EB410 and B64D. Was going to just get the B64D but I was reading that the EB410 is a durable car. I think something that could handle a new driver better would be better for me. Most guys at the track are using associated. It's an outdoor bumpy dirt track with dusty to sandy conditions most of the time. (mostly the reason I'm switching over to a 4wd car) What are your thoughts for the guys who have driven and worked on both?
its always a good idea to use what most of the fast guys at your track are using. Plenty of setup tips and parts support for the B64D. As for the EB410 its a tank and can take a pounding plus its easy to drive. I would just talk to people at your track that drive both and go from there.
Justin805 likes this.
Mononga is offline
Old 11-20-2017 | 09:47 AM
  #2439
Racerx336's Avatar
If I remember correctly I swapped to a 69T spur. Ill have to see where I was with gearing. Maybe one tooth lower than what the manual suggested with the 70T.
billdelong likes this.
Old 11-20-2017 | 10:45 AM
  #2440
Is this the locker you're referring to? If so, what else is required? I'm assuming diff shims to space it?
B64 FLITE 75t CENTER SPOOL SET, for 17.5 and 13.5 spec - Exotek Racing
Bob Barry is offline
Old 11-20-2017 | 11:13 AM
  #2441
EbbTide's Avatar
It's carbon fiber goody time once again folks! It looks like the people over at Bezerk RC have considered our worries about the top mounted fan not fitting under certain bodies and their angled fan mount seems to be the ticket! Check 'em out. I ordered the fan mount/center diff cap, and just the standard center diff cap. All came out to $26 shipped. Though shipping will probably be like snail mail lol.
Bezerk RC
EbbTide is offline
Old 11-20-2017 | 11:16 AM
  #2442
Yes that is the locked Diff. With a little shimming it fits perfect.
Mononga is offline
Old 11-20-2017 | 11:19 AM
  #2443
Bezerk RC
I also looked into the Bezerk RC locked diff but you also need to buy more parts with it. With the Exotek is one and done. I also had to order it from Hong Kong and it came within a week. Had a guy at our local track try to find one and could not.
Mononga is offline
Old 11-20-2017 | 11:21 AM
  #2444
Thanks for the info. I will need to try it with a smaller spur and see how it feels.
Mononga is offline
Old 11-20-2017 | 11:23 AM
  #2445
do you need a different front drive shaft? I remember reading some guys using the B64 diff that required a different front drive shaft.
