Team Associated RC10B64 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree710Likes
Last edit by:
Print Wikipost
Old 11-16-2017 | 09:44 AM
  #2836
Hey guys ive had my b64d for about a week now and im using cavs latest setup on the site but i still need more steering in the corners. Im using yellow front spring and green rears as hes using red front and white rears. And i went to 32.5 oil im the front and it helped a little. Im also running 18mm ride height and 10k/300k/10k diffs. What would be the best thing to change to get more steering?
Cday is offline
Old 11-16-2017 | 09:55 AM
  #2837
I'd go 1mm lower on the front than the rear and go one spring harder at the rear. That should sort it.
Piles is offline
Old 11-16-2017 | 01:30 PM
  #2838
Wildcat1971's Avatar
Tech Prophet
how much toe out?
Wildcat1971 is offline
Old 11-16-2017 | 04:57 PM
  #2839
rigor's Avatar
Most notable things I've done that had a positive impact on steering - more steering and/or better steering:
+1 ackerman plates from Schelle - These were great! and pretty cheap to boot. Highly recommend.
Brass B block
Softer front sway bar (black)
Stiffer rear springs (gray - but I'm on high bite)
rigor is offline
Old 11-16-2017 | 10:14 PM
  #2840
Yes type 1 shells steering plate will make Sharpe turns but makes the car twitchy
eddosi is offline
Old 11-17-2017 | 08:11 AM
  #2841
7k in rear diff
racingnewb is offline
Old 11-17-2017 | 09:58 AM
  #2842
rigor's Avatar
My car is not twitchy. Tune and dial it in!
rigor is offline
Old 11-17-2017 | 11:08 AM
  #2843
kdub's Avatar
Typically with the Type 1 I run thicker front diff oil than rear, 10-7 or 15-10 on the front-rear diffs.
We also have the new Type 3 which is less ackermann, less initial turn in. I would recommend those for more smooth and flowing tracks. The type 1 are very fast in the tight turns.
kdub is offline
Old 11-17-2017 | 08:26 PM
  #2844
this is good screwz for my b64d buggy ?
taztal3 is offline
Old 11-17-2017 | 09:04 PM
  #2845
thanks for the advice
eddosi is offline
Old 11-18-2017 | 12:46 AM
  #2846
Rivkin finishes 3rd overall with the B64 at the worlds with the win in A3!
Scott R likes this.
190mph is offline
Old 11-18-2017 | 09:58 AM
  #2847
STLNLST's Avatar
Type1's are on the car and ready for tomorrow's turkey race at LSR. Will let you know how it goes. Front top deck also installed for it's first run.
STLNLST is offline
Old 11-18-2017 | 07:55 PM
  #2848
speedracer109's Avatar
Just got the B64. Does that 13 degree front caster blocks make a big difference in the handling of the buggy? This thing is a twitch monster and I m try to mellow it out. I also had to cut my steering end points way back as well it had way too much steering. Any help is appreciated. I'm sure the info is in here somewhere, but way to much to Reed through it.
speedracer109 is offline
Old 11-18-2017 | 08:03 PM
  #2849
not sure but I do know that 10 degree caster comes in kit.
eddosi is offline
Old 11-18-2017 | 08:14 PM
  #2850
You are correct
