Tekno RC EB410 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree2421Likes
Last edit by:
Print Wikipost
Old 10-11-2017 | 08:52 PM
  #1486
Ok that makes sense, I've not run that much on carpet. thanks
AJrollin is offline
Old 10-11-2017 | 09:17 PM
  #1487
JsK's Avatar
JsK
Carpet/turf tires generate so much grip they are capable of overwhelming the sidewall/ carcass. This is much more unlikley with clay and dirt tires. So on dirt weight can equal traction, on carpet it simply speeds up the inevitable unless you traction roll first. Its not uncommon at all to pick up grip with a sway bar since its purpose is to more evenly disribute weight tranfer. Or stiffer front springs will generate mid and exit steering. If it helps think of tires as a ball of springs. Any time you solid stack a spring your lose grip very quickly.
JsK is offline
Old 10-11-2017 | 09:19 PM
  #1488
JsK's Avatar
JsK
No problem, carpet is a different animal.
JsK is offline
Old 10-11-2017 | 10:48 PM
  #1489
My very unscientific corner weights, Actually the weight is more centered than you think because the center diff is behind the center and the shocks are behind the arms.
DG Designs is offline
Old 10-12-2017 | 03:22 AM
  #1490
jmcelroy42's Avatar
91g difference on cross weight
jmcelroy42 is offline
Old 10-12-2017 | 06:18 AM
  #1491
I wouldn't read into that cross weight at all. Three twists on a shock collar and it will be perfectly even.
Thanks for the rough corner measurements! 40 grams extra on the front of the car out of the box still seems sub-optimal to me. Might work on a few surfaces, but knowing you have to add extra weight to adjust the front/rear bias is unfortunate. Wonder how long until we see speed controls and receivers mounted behind the center diff.
Krio is offline
Old 10-12-2017 | 06:23 AM
  #1492
Actually now that you mention it I haven't evened out the shock collars yet! I heavens even set the ride height.
  #1493
probably when you do it.
ezlight is offline
Old 10-12-2017 | 06:25 AM
  #1494
hahaha, then try those weights again.
I get my kit and all electronics friday. So I should have corner weight setup by late monday night (Previous engagements friday, saturday, AND sunday! ugh!)
ezlight is offline
Old 10-12-2017 | 06:47 AM
  #1495
JRSlash's Avatar
Parts are available at tekno's web site. Most parts say ready to ship. I got an order of spares this morning. Just waiting on the car....
JRSlash is offline
Old 10-12-2017 | 07:27 AM
  #1496
I would just put that brass weight on before moving the esc
Bob Barry is offline
Old 10-12-2017 | 07:59 AM
  #1497
JRSlash's Avatar
Anybody can tell me the dimensions of the chassis? The total length and total width? I want to know if my chassis protector will cover the whole chassis or have to get another one. Carpet track rules; we have to have a chassis protector.
JRSlash is offline
Old 10-12-2017 | 08:47 AM
  #1498
Chassis 4 1/2 wide by 13 1/2 long. I am going to use the JC universal #1155. It is perfect length just need to trim the sides. 2 sheets for $8 retail.
JRSlash likes this.
E-Mann is offline
Old 10-12-2017 | 09:09 AM
  #1499
rcnut87's Avatar
Originally Posted by Fluxit9
I'm right there with you. As long as it pops before the e-cash ends on October 15th I'll be okay. But I'm tired of waiting!
If they don't get it by the 15th I'll probably cancel my order and hit up Amain.
Going to be real skeptical if all of a sudden Tower ships all there kits on Monday right after e-cash ends.
Cain and jmcelroy42 like this.
rcnut87 is offline
Old 10-12-2017 | 09:10 AM
  #1500
...Carpet track rules; we have to have a chassis protector.
For those interested in a custom chassis protector, I've had really good luck with Dutch Oven Designs, you can send him any graphics you want or explain what you need and he'll make it happen, not sure how soon he'll have templates for the EB410, but I would imagine very soon:
Chassis Protectors : Dutch Oven Designs, Custom Print Solutions at an Affordable Price!
billdelong is offline
